Results 16 to 20 of 20
Thread: Head gasket for 4agte
    perth
    Default Re: Head gasket for 4agte
    copper gaskets can be a prick to seal some times but once it seals it seals and can become a small mission to get it off again.
    mls is a strong easy gasket some have o-rings in the gasket wich seal pressure well and are alot "ALOT" stronger than a standard gasket.
    copper is like the big daddy of the bunch (with o-ringed block) most of the big cube high-comp, massive boost and nos drags cars use copper with o-rings.
    becuase you have had your block oringed id go the copper atleast give it a go and if you go copper get some sealer called "coppercoat" its from "vht" you spray it all over the gasket to help seal everywere.
    Thanks dude...any idea where I could purchase a copper one from? I have been looking on some online stores...but can't find anything.
    Do you know if they are much more expensive than a MLS gasket?
    4AGTE 1990 Corolla SX
    perth
    ask around at some machine shops or give rockett industries a call.
    there about same price as a mls but some brands are a bit more.
    Toymods Club Member Backyard Mechanic Big T's Avatar
    Quote Originally Posted by Big T
    Found it.... Ridgecrest Engineering. They specialise in copper hgs.
    Give them a search and ring them. I'm pretty sure they make any copper hg to any spec you need. Pretty cheap too.
    Eddie.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
    S.A
    Not a cometic one. It's a HKS 1.6mm bead type. I got it for just under $180 which i thought was pretty cheap.
    Eddie.
    BARGIN!!!!!!!!!!!!!!!!!!! I paid about $400 for my 2mm one. but hey speed costs!
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 11:36 AM
  2. Changing 1GGTE Head Gasket
    Last Post: 31-03-2006, 09:26 AM
  3. 4age head gasket thickness
    Last Post: 06-03-2006, 04:42 PM
