The tools you have should be OK, but be careful when getting the gasket off that you don't damage the aluminium. Also, get a big oilstone and rub both faces gently before putting the head back in, it helps the sealing. If you can get an ARP bolt kit, do it. Well worth it, they'll hold torque much better than the factory bolts (which may be knackered anyway). Apart from that, if you're getting the head checked/machined anyway that side will be OK, while you've got it apart check for corrosion and suchforth...and check anything else that's easily replaceable. Good time for a new timing belt etc too...
RM.
ahahahha
ahahha
