Page 7 of 8 FirstFirst ... 5678 LastLast
Results 91 to 105 of 118
Thread: Pulley Fabricators(now with pic)
  1. #91
    Default Re: Pulley Fabricators(now with pic)
    You got that in the mail?
    Which one is the water pump? I assume it is the bottom one?
  2. #92
    Naa thats the one at rare spares...yep the one with 9 holes is water pump...going in to measure the water pump bolts now..
    -Just Alloy Radiators-
    www.alloyradiators.com.au
  3. #93
    Ok, and the cost of that setup?
  4. #94
    $275 minus belt,belt $60 extra but the one on ebay is $150 inc belt...I have already bid on it hopefully he doesnt bid on his own auctions and it stays 150 and 20 shipping
    Ok just measured the water pump bolts and from center to center they are 40mm, 45mm outside of the bolt to the outside of the other,so it looks like we will have to make up some sort of adapter for that aswell..anyone got a spare 3t lying around to see how this crank pulley comes off??
  5. #95
    Ill go measure the 4A ones, i think they are a fair bit bigger than those ones
    57mm, with a 30mm center hole. Not much clearance back wards though, how thick is that pulley?
  6. #96
    naa sorry thats not the diameter of the pulleys..
    57mm is diameter of the center hole of the crank pulley,the total diameter is 115mm,105mm for the water pump and 70 or 75mm for the alternator..
  7. #97
    Nah, that was dimensions of the bolt spacing on the 4A water pump pulley. Shoudl be able to machine out the center hole and adjust the boltspacing for that one quite easily.
  8. #98
    Cool,here is the measurements anyways
  9. #99
    Diagonally?
  10. #100
    46xsqrt(2)
    prolly more like 62-63 from edge of holes tho..
  11. #101
    Yeah, i was more thinking about the other set of holes. They look a whole lot more like high 50s.
  12. #102
    Yeah sorry guys I should have been more thorough in my measurements,I actually had to ring him up to get those as i lost the bit of paper with all the measurements on it..hahaha those other holes in the water pump pulley definately look like speed holes to me...
  13. #103
    Quote Originally Posted by RiceburnaGTV
    Yeah, but with a bit of constructive filing the stock mounting set can become speed holes and the speed holes mounting holes.
    Alternator looks perfect though.
  14. #104
    How much can you afford to space them out? If you can get a 20mm spacer behind each pully, I can make it fit anything.
    RM.
    Edit: Come to think of it, with that much room to play with I might be able to get some sort of dampening system in the crank pulley....
  15. #105
    Quote Originally Posted by mullett
    RM.
    mmmm 20mm might be pushing it.I know the small block ford one's crank pulley is spaced out that far.How will this help? Dampening system?
  1. Stuck crank pulley bolt
    By Shifty in forum Tech and Conversions
    Last Post: 05-04-2006, 10:37 AM
  2. alternator pulley idler torque setting
    By SpleenieMcSpleen in forum Tech and Conversions
    Last Post: 25-03-2006, 12:19 PM
  3. 4ag crank pulley sizes
    Last Post: 08-02-2006, 07:27 PM
