I sometimes wonder how well people setup ECU's with the comments that are generally posted on here, my Microtech on my 4AGTE started perfectly fine at temps down to -7 degrees just like it should have, simply turn the key it starts idling at 1350rpm and tapers down to 780rpm at operating temp - done. It also ran the 4AGZE it came off without any issues too.
Idled perfectly fine under any conditions I came across regardless of temps or electrical load. I never had AC though but I if I did I simply would have setup a standalone idle up valve. That's the thing with some of the cheaper ECUs, they lack the outputs/inputs and configurability, but hey, that's why they are cheap. You don't buy a Hyundai and expect Ferrari performance
I just removed my old ECU yesterday are about 5 - 6 years of good service to fit an Adaptronic so I can see what all the fuss is about and make use of some of the extra features I've started to need and that the old Microtech can't provide.
As noted the Adaptronics seem like a decent bit of gear for a good price and they'll control ISCV's of any sort I can think of, from two wire Ford style to the 6 wire stepper motors on Subarus. I'm going to try it initially on a 3 wire bosch ISCV and then later on a 5 wire Subaru stepper motor.
Also the act of switching the SC be annoying, especially with limited outputs (like the microtech). In the end I had to use two outputs on my EMS, one switched on at 3500 rpm (so the SC wasn't switching at high speed/flicking on and off through a corner) and one which switched on at less than 30% vacuum. This was as close as I could get to the factory setting without adding a delay circuit (like the factory ECU).
On a microtech you just use one output and set the rpm and vacuum switching points. Granted microtechs don't have any hysterisis built in but utilising two switching values for the one output seems to overcome any issues associated with that.
When choosing an ECU do your research, ask yourself what you want it do and find a tuner you're confident in. There are tales of woe with almost every ECU and for the most part it comes down to poor setup and tuning.
