Results 1 to 3 of 3
Thread: fuelling issues
    brapbrap Domestic Engineer samoo's Avatar
    Default fuelling issues
    Pull into carpark other day in my 85 mx73 and it stalls.
    Goto turn it on when I leave it starts, then stalls. Try a few more times same thing, then eventually doesnt start. Get it towed home.
    Suspect dead fuel pump so undo the banjo bolt off the fuel rail and turn ignition on, no fuel.
    Check fuses, all ok
    Multimeter on fuel pump, 0 reading.
    What/where do I go next?
    no more aw11
    mx73 and brap brap time now
    Default Re: fuelling issues
    So i checked the relays in the cabin, they all seem good.
    Couldnt find the fuel pump one?
    arent fuel pumps
    Fuel Pump Relay
    Part No.28360-70030
    (NipponDenso 058700-2240)
    all i could find was 4x
    EFI and others Relay
    Part No.90987-02002
    no more aw11
    T'ville, QLD
    try running a live wire from IGN to the fuel pump (fused of course!!) see if she runs ok, then i guess trace the wire from the fuel pump to the relay and see if its shorting on somthing or has a loose or broken connection, find which relay it runs to and test that and if ya still cant find the problem, give up?
    2T out 4A in....
  1. Wheel fitment issues hELP
    By 77GZE in forum Tech and Conversions
    Last Post: 05-11-2008, 12:01 AM
  2. Alternator/Charging issues.
    By DoctorDubb in forum Tech and Conversions
    Last Post: 07-03-2008, 04:44 PM
  3. 1G-GTE hilux - running issues
    By THREAT in forum Tech and Conversions
    Last Post: 12-06-2007, 11:03 AM
  4. 1GGZE Supercharger Relay Issues
    By infotechplus in forum Tech and Conversions
    Last Post: 26-05-2007, 03:47 PM
