this is a quickie, but.. if you have a beefy soldering iron, try to resolder the wire joins inside the alt.. as some of them may be dry, or have cracked from vibration.
the other thing might be that the wiring is just too dodgy...
perhaps hook up a seperate light for the ALT lamp, away from the original wiring... basically, temporarily redo the wiring including the main charging wire to the batt, and see if that helps...
to help diagnose diode issues, using a 10 LED battery voltage indicator, like the jaycar/DSE ones, can help.. iave had a few cases where one diodes solder has failed (both denso and bosch alts), and it results in the voltage being seen to cycle on the LED display.. even tho the multimeter says the voltage is constant
http://www.jaycar.com.au/productView...Max=&SUBCATID=
edit, when you checked the diodes.. did you unsolder them from the coils first?
