Results 1 to 5 of 5
Thread: Bleeding ABS Systems
    Nov 2007
    Default Bleeding ABS Systems
    Should ABS Brake systems be bled in a different way than normal?
    I read that you have to purchase some kind of scan tool for your car
    to cycle the valves in the ABS pump to get air bubbles out.
    Or will bleeding it the normal way, having a friend in the seat
    pump the brakes while you tighten/loosen the nut on the bleed
    nipple work?
    Thanks.
    Original Trendsetter Chief Engine Builder Harreh's Avatar
    Jul 2008
    Default Re: Bleeding ABS Systems
    HEHEHEHE Nipple...
    Seriously though, I'm 99.99 percent sure you need a power bleeder for ABS
    AW11 Turbo build
    1UZ Soarer Turbo build
    Imitation is the most sincere form of flattery
    Chiba
    Would one of those pressurized thingos that attaches to your master cylinder work?
    Strange Grease Monkey w0n0matic's Avatar
    Feb 2008
    Bleeding Anti-lock Brakes�is it really as difficult as it sounds?
    by James Walker, Jr. of scR motorsports www.teamscR.com
    April 22, 2001
    In general, whenever you are bleeding an ABS-equipped vehicle you can do so exactly as you would any other vehicle - stroke the pedal to pressurize the system, open a bleeder, close the same bleeder, and repeat. This does not change whether you are pressure-bleeding, vacuum-bleeding, or manual-bleeding. Just follow the same steps you normally would for a non-ABS vehicle and you're most of the way there.
    Operative Word: Most
    Now, with some ABS devices, you are actually done no matter what (Delphi's early ABS VI, for example). Bleed as above, and you are finished. Note that there are some special situations where the retailer will perform a diagnostic bleed of these early ABS units, but this is not within the scope of this article. Stop reading, and go get a drink.
    However, other ABS devices have their own internal reservoirs (Bosch ABS5.3, for example) that are not a part of the primary brake circuit and are only opened to the rest of the circuit when the ABS is active. Now, if you just bled your system per the above technique and never again cycled your ABS, you would be fine. However, as soon as the ABS cycled - even for a few tenths of a second - the "old" fluid (which was never bled because it was hidden) would be dumped into the primary circuit. Not the end of the world, but you want fresh fluid everywhere, right?
    The Factory Procedure
    With these systems, the correct way to bleed the ENTIRE vehicle is to employ a Dealer service tool (it usually looks like a Nintendo GameBoy) that allows you to cycle the ABS valves and/or the pump motor WHILE you are bleeding the brakes. In effect, this allows you to open the hidden passages in order to purge the fluid completely. Fresh fluid is then drawn into the ABS unit, and the old stuff can be flushed away with the rest of the mess. Nothing to it.
    The end result takes a little more time than a conventional bleed, and requires you use a little more fluid, but looks like this:
    Step 1 - Manually bleed RR, LR, RF, LF brakes
    Step 2 - Install service tool and cycle all valves and/or pumps
    Step 3 - Manually bleed RR, LR, RF, and LF brakes again
    You end up having bled the system twice, but this is necessary to ensure that fresh fluid - and NOT used fluid - is drawn into the unit the next time that the ABS valves (and/or pump) are cycled.
    The 75% Answer
    The last 25% of course is "does my car have these mysterious hidden passages?" That's for you to find out, but the following information should be useful in your quest for ABS knowledge.
    As with any technology, manufacturers have produced several types of ABS over the years, and listing them all is simply not possible. In general, the most recent ABS product offerings - Bosch ABS5.7, Bosch ABS5.3, Delphi's DBC7 - all DO have the hidden passages and would require the procedure listed above. However, you cannot always rely on this generalization alone.
    Our advice? Make a phone call to your local service department asking what their procedure is to bleed the brakes WHEN A NEW ABS UNIT IS INSTALLED (as opposed to when they change a caliper). If they claim that they need to cycle the ABS, it's a good bet that you need to also.
    But What If I Don't Have The Dealer Service Tool?
    If you really feel the need to cycle the valves, but do not have access to a service tool (or if the dealer is not willing to loan theirs) you COULD just replace Step #2 above with "go driving and slam on the brakes a few times to make the ABS work" to purge the used fluid from the unit. This is usually NOT the most efficient nor socially responsible solution, though it seems to work just fine. You still need to bleed the car a second time, but it saves you from procuring the service tool.
    But what about when I'm at the track?
    Remember that this is the process for FLUSHING AND FILLING YOUR ENTIRE SYSTEM. If you are only replacing a caliper or performing any other operation where you are simply trying to bleed vapor and/or used fluid from the wheel-end components (like after a hard day of lapping,) you need only to bleed the brakes as you normally would...ala Step #1 above.
    There is no reason to cycle the ABS if all you are simply trying to do is get vapor out of the calipers. For this reason, if you flush and fill your system only once per year, the rest of the time you will not need to perform the ABS cycling procedure�or worry about the service tool at all.
    hope that helps
    New Zealand
    The easiest way I have found to do it properly is to pay $45NZ to Pitstop (or similar places in Oz) and pick the car up later. For the cash you save I decided it wasn't worth pissing around with, by the time you fund beer for your helper it isn't far off that anyway. Just remember to tell them to bugger off when they want you to get other work done like machining discs etc.
    Callum
  1. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 01:42 AM
  2. Bleeding brakes and fluid choice question...
    By deviant in forum Tech and Conversions
    Last Post: 25-01-2007, 05:47 PM
  3. Trouble bleeding brakes (still spongy)
    By CrUZida in forum Tech and Conversions
    Last Post: 12-09-2006, 08:30 PM
  4. Replies: 0
    Last Post: 20-07-2006, 12:18 PM
