Results 1 to 13 of 13
Thread: 1uz-fe won't idle,any ideas?
    Jan 2008
    queensland
    Default 1uz-fe won't idle,any ideas?
    I have wired up a 1uz into my 2wd hilux and it ran fine,idled, revved cleanly but all of a sudden it won't idle now, the only thing i did was wire in the alternator so i unplugged it and it still won't idle. I should point out that the conversion is not finished yet and the radiator is not in yet so its only run in for seconds at a time. It has only got the five wires and hard wired fuel pumps at the moment to run but i can't figure out why it changed all of a sudden,any ideas welcome,thanx Mick
    Mar 2008
    inner west syd now!
    Default Re: 1uz-fe won't idle,any ideas?
    wat do you mean by it wont idle??
    does it rev up and down?
    does it just stall?
    if it idles up and down it could be the idle speed control valve isnt plugged in properly, or its damaged, or your intake is leaking (after the iscv)
    if it just stalls, not sure, try re-setting ecu and go from there!
    it could be lots of things!
    Finish the installation properly, wire it up properly as per Toyota wiring standards, and THEN chase the idle problem.
    User Conversion King
    NWA
    from past experience, people often neglect to supply power to the ISCV. the 2 inner pins need +12V switched from the ignition.
    hello
    Modify is my middle name Grease Monkey Darola's Avatar
    Hey there mate... finish wiring everything up as the computer would be looking for all the sensors to know the motor is running.... thats more then likely the reason as the computer is looking for everything and not getting a answer back....
    Ed
    Eddie 0433 85 69 66
    Jan 2008
    queensland
    Tanks for the prompt replies guys, will finish install before tackling any gremlins,i didn't know about the isvd thingy so will check that out too.
    Jun 2007
    Yeah mine was playing up too, but after exhaust system (O2 sensors fitted) & fitting a small 3mm restrictor from the inlet side to iscv idles alot better & getting better the longer it runs too.
    If you've fitted a restrictor on the ISCV it means the ISCV is not working.
    Jan 2008
    queensland
    please explain
    The ISCV is designed to work without any restrictor. It will keep the RPM to what the ecu wants (depending on conditions).
    If you have found that the idle is too high, and by fitting a restrictor is has come down to something more acceptable, then the ISCV is not working.
    Either because
    a) its not wired correctly
    b) its faulty, or
    c) the ecu is not entering idle mode because the TPS is not configured properly.
    Jan 2008
    queensland
    Got it thanks mate
    Jun 2007
    Question TPS is???? (Throttle Position Sensor????)
    yeah dood.
  1. 1uz ITB manifold adapter plate .dxf file
    Last Post: 29-10-2021, 09:49 AM
  2. 1uz oil filter locations
    Last Post: 28-03-2008, 05:46 PM
  3. 1UZ VVTI... Wiring questions.
    By MWP in forum Tech and Conversions
    Last Post: 07-06-2007, 03:00 PM
  4. Replies: 23
    Last Post: 29-04-2007, 12:18 PM
