Results 1 to 13 of 13
Thread: replacing cam gear on 1jz
    Default replacing cam gear on 1jz
    do i have to take the crank pulley off to get to the timing belt tensioner on a 1jzgte? if so that will suck balls because my motor sits so low in the bay that i would have to take the motor out to get a rattle gun onto the crank pulley bolt
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Junior Member Backyard Mechanic manny's Avatar
    Default Re: replacing cam gear on 1jz
    No, you don't need to touch the crank pulley on a 1jz-gte to loosen/remove the timing belt tensioner - just use an socket extension to reach and loosen the two bolts either side of the tensioner.
    GSE20 IS250 - daily
    UZZ30 Soarer - 1UZ-FE/R154/Adaptronic - trackday roughie
    UZZ32 Soarer - Active Hydropneumatic Suspension (A-SUS) & Active Four Wheel Steering (A-4WS) - cruiser
    ok im a bit new to the whole 1jz thing so forgive my ignorance. I am attempting to install an adjustable cam gear on the exhaust side reason being its a vvti version so only 1 will go on.
    So is the fan belt tensioner the timing belt tensioner also? how do i release/loosen the timing belt tensioner to get the cam gear off?
    12.4 @ 110mph
    Very different tensioners mate - have a read of this belt replacement guide for the 2jz-gte which will give you an idea of the parts involved.
    http://www.supras-ireland.net/manual...eplacement.pdf
    In a nutshell you need to loosen the tensioner in section 8 (a) of page 4 (EG-25) to allow enough timing belt slack to slip the exhaust timing gear off and the replacement back on underneath the belt without skipping any teeth on the intake cam or crank shaft.
    Not a job for the faint hearted or inexperienced but doable for your average tinkerer with a bit of preparation and the right tools.
    GSE20 IS250 - daily
    sweet mate cheers, i also found this one too
    http://www.toymods.net/forums/showthread.php?t=14262
    12.4 @ 110mph
    doneski! peace of piss, thanks manny!
    12.4 @ 110mph
    Thumbs up Re: replacing cam gear on 1jz
    Great effort, great result !
    Does she start and run?
    GSE20 IS250 - daily
    yeah starts and runs as good as it did before hand. now it just needs a bit of adjusting and a tune!
    12.4 @ 110mph
    Hey Manny , Any chance you could use the same method for changing camshafts on a normal 1jz ? Or would you suggest doing it properly ?
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
    http://www.youtube.com/watch?v=tc_7aRUGshw
    You do slacken off the tensioner bolts in a similar manner but you would need to do a bit more work to remove the cams - besides both camgears, the sheet metal plate behind the cam gears needs to come off to get the front cap(s) off properly as well as lifting the camshaft(s) vertically.
    You would also want to replace the cam seal while you're at it as well as ready access to applying FIPG betweem the front caps and head.
    GSE20 IS250 - daily
    what the mang is on the intake cam sprocket?
    Quote Originally Posted by HAVABEER
    It's VVTi, that's what they look like
    Wilbo's JZA80
    Wilbo's JZZ12
    Yeah Thanks Manny ... I thought that, but just wanted confirmation .
    Still going good
  1. JZA70 and MA70 Specifications
    By twentyEight in forum Tech and Conversions
    Last Post: 18-12-2016, 11:18 AM
  2. w58 with 1JZ
    By hecate in forum Tech and Conversions
    Last Post: 25-07-2008, 12:24 PM
  3. sticky first gear - ae111 6spd.. help!
    By chiksluvit in forum Tech and Conversions
    Last Post: 14-10-2007, 09:57 AM
  4. w58 were do i come from
    By AE71GZE in forum Tech and Conversions
    Last Post: 26-02-2007, 02:26 PM
