Results 16 to 30 of 42
Thread: 1UZFE Timing belts
    Default Re: 1UZFE Timing belts
    Here you go mate. They were from Lextreme afterall LOL.
    http://www.lextreme.com/PDF/timingbe.pdf
    http://www.lextreme.com/PDF/waterpump.pdf
    The guide posted by marc280 is very good. I used that as well.
    Just keep in mind its specifically for the LS400 so some of the little bits are different. (i.e. some of the accessories may be a little different so there may be extra bolts or not as many on some bits)
    Act
    cool thanks MX73
    I should be right I was going to do it without a manual so any hlp is great
    matty its auto unlike a lot of 1UZ's this one is still in the car it started life in
    Luke, I can photocopy the relevent pages from the 1UZ-FE engine manual if you need them.
    cheers Chuck.
    MS51Crown Coupe,
    Act
    well well finally gotten to this what a **** of a job.
    All the links above are a great help
    after a few hours I'm a good part of the way of removing it all
    hey stitty is it true these dont have adjustable CAS? so fixed timing?
    Act
    yes I couldn't see anywhere to adjust it yesterday
    No adjustment
    Correct-o, there is no manual adjustment, the tensioner keeps it at the right tension all the time
    (hence its' name?)
    Act
    no he is talking about fixed timing. Not fixed tension on the belt
    Fuck I hate toyota atm, there where two bolts that mounted the fan mount, that went through the AC comp mount and shit on a UZS131 there are in a crap spot, A Celsior and or Soarer the chassis might be different and these bolts would be easier to get to. But god there are in a crap spot on the Crown
    I see. Well i imagine timing adjustment would be controlled by the ECM.
    I pretty much have no helpful advice on this matter.
    I think i know the ones your talking about. (I didn't realise they were there and couldnt move the fan pulley lol)
    i got one from underneath the car with long extension and socket and the other i had to use spanner because there was a/c line in the way.
    i feel your pain, it took me week and a half between going to work and stuff.
    Yeah, the timing and advance is controlled electronically. There is no way to adjust base timing.
    I dread the day when I choose to do the timing belt and water pump on the Celsior
    Act
    can anyone tell me if I can just pull the cam pulley off to get to the cam seal, or if I have to remove the a hole lot more stuff.
    I had to use a spanner, and bend my hand as A/C lines and chassis where in the way
    I think the black pressed steel cover needs to come off, which its easier said that done.
    But its been a long time since I've done it.
    you gotta remember Stitty that the 130-series crown was designed for the 7M..... they only shoved in the 1UZ cos they had a whole heap of spare 1UZs and were getting sick of 7M-BHGs.
  1. 1uz timing belts
    Last Post: 01-04-2008, 09:18 AM
  2. timing curve(s) for 18RTE
    Last Post: 20-04-2006, 12:50 PM
  3. RWD 4AGE Timing issues.
    By Rallystanza in forum Tech and Conversions
    Last Post: 11-01-2006, 09:03 AM
