Results 16 to 20 of 20
Thread: 1ggte water temp sensor
    Default Re: 1ggte water temp sensor
    Could it be that it uses the block for earth/current return?
    Junior Member Automotive Encyclopaedia Big rob's Avatar
    thats what i was thinking, just thought it was a little odd that they did that rather than ran a cable as the others do. Maybe, no it must ahve saved them money lol. I cant see any other way other than it running through the block.
    Anything the ecu uses needs it own earth, hence its not a good idea to mess with it, as it can change readings.
    The guage sensor however, is not as important.
    awsome didnt know that. I guess i could just try it. If it doesnt work, i'll do sometihng else.
    Thanks Cruzida
    Yes, the Temp Guage sensor is pull to ground, so it uses the Block as the ground. IE the guage itself puts power to the sensor and gets the resistance off that.
    Facebook | LinkedIn
  1. ECU jzx100 pins
    By splatt in forum Tech and Conversions
    Last Post: 30-08-2011, 06:11 PM
  2. Water temp gauge install
    Last Post: 21-02-2006, 10:45 PM
  3. 1JZGTE With Microtech LTX-12...what air temp sensor?
    Last Post: 16-02-2006, 10:38 AM
