Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Thread: Compression 20V Blacktop
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    Default Re: Compression 20V Blacktop
    For sure. I might get some T3 gear soon.
    AE93 SX - Thrasher 20V
    JZX100 Chaser - Daily 1J lovin
    New Zealand
    um dont run open trumpets lol
    please, no more PMs!
    South Austrlia
    I'll be putting filters over each one and running a big air pipe to them.
    New Zealand
    you will lose rather a lot of power from stock doing that
    the stock air box and set up is very good for a stock engine.
    if you do cams etc then you can make some mods to the rest of the intake.
    but opens trumpets with filter socks are not a good option.
    South Austrlia
    Mmm...I've got a whole list of parts I wanna get. What sort of cams do you recommend for daily use?
    Shopping list includes T3 trumpets, pulleys, 3.7Kg flywheel and custom extractors.
    New Zealand
    im no cam expert
    but sounds like your of to a better start than i assumed!
    toyota spent a lot of $$ on designing that surge tank. so while it can be improved on for certain applications. its not as easy as just biffing on some trumpets
    Han Lue aka Robin Hood Grease Monkey DreadAngel's Avatar
    Nov 2007
    STATE
    For my 2nd engine, I was initially planning on 288/288 or 272/288 but after speaking with a few guys with similar setup, I don't like the idea of no balls below 4K and then a roadtrain after lol =P
    Plans atm is 264/272 =) Some poke with balls =D
    Not here anymore!
  8. #38
    South Austrlia
    Sounds good.
    I think my VCT is starting to go cactus. At higher RPM the motors is pretty rattley.
  9. #39
    Nov 2007
    STATE
    VTC...
    Do you know how to test the VTC to see if its the VTC giving you the musical symphony of a diesel engine =P
    I'll see if I can find that doco I saved up somewhere lol
    Not here anymore!
  1. My high compression + boost concept
    Last Post: 18-06-2012, 09:40 PM
  2. compression guesstimating..
    By DeftAnesthetik in forum Tech and Conversions
    Last Post: 20-04-2008, 06:45 PM
  3. Discussion: Blacktop 20v: The road beyond 200hp
    By 86er in forum Tech and Conversions
    Last Post: 18-01-2007, 10:31 PM
  4. Selecting a compression ratio for a 20V
    Last Post: 05-07-2006, 10:09 PM
  5. 20v compression (compression test)
    By 2revup in forum Tech and Conversions
    Last Post: 20-03-2006, 05:06 PM
