Results 16 to 30 of 39
Thread: Compression 20V Blacktop
    Low rep Grease Monkey
    Default Re: Compression 20V Blacktop
    my blows blue smoke now that would have to be the rings
    can it be the tune ?
    New Zealand
    whats the history? have u just bought this? or done a cam belt? they dont just go out of timing so what im getting at is was something done to put the timing out? like did you work on it then it happened, or has it always been like that?
    when setting/checking the timing did you bridge the diagnostic terminals?
    if it wont start now, it was probably correct in the first place.
    http://home.onthenet.com.au/~paulp/Blacktop/
    there is a PDF of the complete black top manual
    it will have the info you need re timing marks etc
    go back to basics, check the cam and ignition timing again and get it to where its meant to be, then you can go from there.
    please, no more PMs!
    EDIT: ooops you already solved the problem with compressions
    Han Lue aka Robin Hood Grease Monkey DreadAngel's Avatar
    Nov 2007
    STATE
    If you don't mind me asking, what the approximate mileage and what grade oil were you using?
    That idle is pretty unusually high for a stock? engine...
    Typically Blacktops unfortunately after their "prime" they slowly die... generally give or take 100,000kms >
    Not here anymore!
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    Quote Originally Posted by Mr Revhead
    I picked the car up nearly a week ago. It didn't feel like a 20V 4AGE at all. I haven't touched anything besides advance the timing a bit.
    I've got the manual and when I did go by those marks, it didn't make sense. Both inlet and exhaust vavles were opening pretty much at the same time. Thats why I'm asking for someone to check their timing marks to see if its the same.
    It works in this position. If the knock pin is in the other groove, no action.
    Good service history
    AE93 SX - Thrasher 20V
    JZX100 Chaser - Daily 1J lovin
    South Austrlia
    Quote Originally Posted by DreadAngel
    No idea. Easily over a 100,00kms and I haven't changed the oil yet and how knows what the previous owner was using.
    Yeah idle was too high so I blocked the ISC hose and it idles at 500 when cold and 1100 when warm.
    Nov 2007
    STATE
    Hmmmm...
    Easily over 100,000kms... The previous owner might've been prolonging the engine's life expectancy using thicker oil hence the sluggish overall performance. Even though they love thin oils, they wear out very quickly these elderly blacktops. Signs of old age would be vibrations, sounding like a diesel on idle [Shims or VTC Cam Gear, last time it was my A/C Pulley =| ], its the same with my car atm, I'm having to use thicker oil, lose a lil performace in search for a more quiet and prolonging its lifespan.
    Typically Blacktops back home get overhauled ~100,000kms so they don't have to worry about all this. Compression so low... doesn't sound good at all
    Not here anymore!
    Junior Member Backyard Mechanic KARNAGE's Avatar
    that doesnt look like the original cam gear for the exhaust side, when i picked up my stock blacktop it had a different cam gear then that. and the amount of sludge underneath that cam cover is horrible. i would say it hasnt had a good oil change for quite some time.
    South Austrlia
    I've seen a few other BT and the cam gear looks the same. Maybe yours is aftermarket?
    Yeah the sludge is shocking. I'll give the motor plenty of TLC soon.
    South Austrlia
    Smile Re: Compression 20V Blacktop
    Picked up another compression tester today and tried again.
    Lowest was about 175psi and highest 195psi.
    I knew the compression couldn't be that low, it seems the hose used to test it out the first time was a bit too long and gave a false reading.
    It still doesn't feel like a 20V though, gotta check the VVT valve and give it a good service.
    what other 20valve are you comparing it to? and what other car have you driven with a 20valve in it?
    South Austrlia
    I've only driven one other 20V and that was in a AE111.
    Nov 2007
    STATE
    Depending on mods and condition, you can really see the difference LOL...
    I mean, after being in/driven a fair few AE111s... =P
    The ones that have had a hard life seriously have big issues leading into 100,000kms let alone afterwards [Diesel Sounds, Noise Tappets, VTC Noise, etc]. Those that have had a good life are still strongish after 100,000kms, they still have the sound of the above but nowhere near as loud. Thats how I usually tell how good/bad a blacktop condition could be...
    Not here anymore!
    South Austrlia
    Yep lol It seems this motor isn't too bad at all. Flush the oil twice, still filth but alot better than before and I poured some fresh Mobil oil in + filter.
    It seems that little changes in ignition timing change the perfomance significantly. I pissed the airbox and snorkels off and took it for a quick spin.
    Sounds awesome and goes alot better with the ignish timing set properly
    Nov 2007
    STATE
    Wait till you get that plenum off and trumpets on
    Lane Cove Tunnel never sounded so alive! Don't do such things
    I laughed when a mate in a Hilux pulled up next to my mate's AE111 and ask if it was diesel LOL!!!
    Not here anymore!
  1. My high compression + boost concept
    Last Post: 18-06-2012, 09:40 PM
  2. compression guesstimating..
    By DeftAnesthetik in forum Tech and Conversions
    Last Post: 20-04-2008, 06:45 PM
  3. Discussion: Blacktop 20v: The road beyond 200hp
    By 86er in forum Tech and Conversions
    Last Post: 18-01-2007, 10:31 PM
  4. Selecting a compression ratio for a 20V
    Last Post: 05-07-2006, 10:09 PM
  5. 20v compression (compression test)
    By 2revup in forum Tech and Conversions
    Last Post: 20-03-2006, 05:06 PM
