Even when you get a magazine you'll find the laser is probably stuffed. And thats a $600 cost to replace.
Been there, done that.
I was surprised at how well the 20 year old pioneer stock sound system sounds in my celsior! i have heard the nakumichi sound system is even better. Im in the process now of wiring in an aux connection so i can connect the ipod to the stock sound system. Cheaper then trying to get the CD changer magazine thing which was missing from mine.
98 3rz-fe Hilux 4x4
my stacker worked perfectly in mine. the sub on the parcel shelf was ratshit. the rest of the speakers were fine though.
Glenn
Current Ride http://www.toymods.net/forums/showthread.php?t=41123
Previous 3SGTE ST162, 1JZ Cressida 215RWKW-ET 13.318, Celsior, XT forester, 3SGE KE70.
Mine was fine with brand new CD's, but anything with a scratch on it just brought up error messages.
wll mine seems to be going pretty hard, reads just bout anything and is clear as a bell with no poping or anything i was kinda expecting there to be some distaution in the speakers but nothing as of yet.
BUT! as alo of people hava said on here the LCD screen in the front that shows the, Time, and the temp of the heater and airconditioner is stuffed its bleeded all the way through so i cant figure out the heater (i no i no NUBE) are these easily replaced what $$$ damage am i looking at?
Do you have C or CF ?
C can be fixed for a couple of hundred.
CF cannot be fixed.
how come the CF celsior LCD's cant be fixed? is that because no one sells a replacement?
I know they sell a replacement LCD for the ls400's for about $160USD and its a bugger to solder in yourself unless your pretty experienced with a solder iron.
On another note i got qouted $1500ea for the front upper control arms (seem to be a commonly worn out part on celsior/ls400's) Luckily i found a place that sells the pair of them for $200USD. Now to order and replace the rest of the front suspension components-
98 3rz-fe Hilux 4x4
No one aftermarket sells a replacement.
You can buy them genuine from Toyota but you have to buy the whole climate control module.
i got a UFC10 Ls400,
we are just talking baout the little LCD screen that is no wider then an inch?
Blue23, Benny at NATRAD Phillip sells the new LCD for UCF10 climate controls.
cheers Chuck.
MS51Crown Coupe,
Originally Posted by "Z" UTE
cool i will look into it
Ditto, stacker is perfect in my car subs distorts with anything over half bass in when the volume is cranked up. XR6 had the same problem with the sub as well.Originally Posted by 1jz68u
Does anyone know of a bolt in replacement for the factory sub. Don't want to go spend too much money but the distortion in songs that contain a decent amount of bass annoys me, what can the factory amp handle as well.
If in doubt power out
well....
i booked the car in today for a check over and service, under close inspection of the car i need:
new timing belt
new runnign belt
new water pump
anyone ghad to replace any of these b4? no of what costs i might be looking at and how easy are these parts to get?
Timing belt & front crank seal for me was around the $1000 mark. Tonnes of labour cost being the main hit due to so much shit being in the way that has to be removed & re-installed.
did they have to go genuen timing belt? hmmmm wow $1000 damn well i guess ill have to wait and see what the damage $$$ is going to beOriginally Posted by RONA
