Results 1 to 2 of 2
Thread: 4age silvertop problem
    Junior Member Grease Monkey toyoda's Avatar
    Question 4age silvertop problem
    ok well, just dropped a silver top 20v into my ae86..
    so far i am having a problem where when you start the motor it doesnt wont to freely rev at any throttle position. then other times you hold it at a constant and it slowly comes up and
    once it is up you can freely rev until it drops back down to low.
    the engine also seems to be running lean as the exhaust manifold is getting rather hot extremely quickly and backfiring.
    any way they are the symptoms i am having atm and so far i have checked a/f meter is work correctly, ecu is not throwing any codes, oxy seems to be fine, fuel pressure is fine.
    any ideas?
    cheers luke.
    Junior Member Backyard Mechanic KARNAGE's Avatar
    Default Re: 4age silvertop problem
    i had a problem similar to that with my old sprinter but it was the TPS was fully F*&KED but that was a 4agte smallport
  1. 4AGE 20V silvertop compresion-power-gearbox
    By CEL_1JZ in forum Tech and Conversions
    Last Post: 12-04-2012, 07:23 PM
  2. Silvertop 20V power problem
    By Buttocks in forum Tech and Conversions
    Last Post: 20-03-2008, 02:59 PM
  3. Bigport 4age spark problem
    By Spode in forum Tech and Conversions
    Last Post: 24-07-2006, 06:40 AM
  4. HELP!!! 4age 100kw major problem
    By sxtc in forum Tech and Conversions
    Last Post: 18-02-2006, 12:13 PM
