Results 1 to 9 of 9
Thread: 3SGTE Timing Belt Installation => Did I do it right (pics)
    cease striving Conversion King RobST162's Avatar
    Default 3SGTE Timing Belt Installation => Did I do it right (pics)
    I am a little paranoid about this, but I assume this is how the OEM marks are meant to line up.
    wa
    Default Re: 3SGTE Timing Belt Installation => Did I do it right (pics)
    ummm....not sure if there's more than one way to do it but i'd put the lower timing belt cover back on along with the crank pulley, line the mark on the pulley with TDC on the cover and then check the cams wheels are lined up......
    Cams are fine... whats the crank pulley lined up with? I normally line the keyway up with a rib on the block
    I am the sun
    Forum Sponsor Conversion King
    It looks correct provided that there is no slack on the right hand side of the belt (turbo side), but as stated when the tensioner is back in slip the lower cover on and check that the crank is at TDC and the cams are still in the same position they were in the top 2 pics.
    If so then its fine.
    linden
    sweet thanks linden and guys, it's frustrating how there's no super clear crank tdc without the cover on, but i'll be popping that bad boy on today, and turn the engine over and check that everything still lines up
    toyota says 0 degrees is the go, i have read (haynes manual) -10 degrees, but i'm going for 0
    Brisbane
    Hey mate, good to see you're playing with a real engine
    wa
    Quote Originally Posted by RobST162
    the -10deg is for your ign/dizzy timing. 0/TDC is for cam timing.
    Brisbane
    Quote Originally Posted by jonathan yee
    correctamundo!
    fwiw: didn't use an OEM belt i matched the marks on the pulleys with marks on the front casting and the metal shell behind the cam pulleys.
    plus I double checked thru observing the camshafts and having a very long screwdriver down spark plug #1 sitting on the piston to confirm it was TDC #1. After setting the belt tensioner, I wound the engine over 2 full revs and then re-checked the marks.
  1. 2JZGTE VVTi Timing Belt Installation, Help needed!
    Last Post: 20-11-2008, 04:05 PM
  2. Timing belt Tensioner
    By KARNAGE in forum Tech and Conversions
    Last Post: 25-10-2007, 08:40 PM
  3. Brand new timing belt tensioner installed - looks unusual (pics)
    By Howieau in forum Tech and Conversions
    Last Post: 06-10-2007, 07:56 AM
