Results 1 to 8 of 8
Thread: Timing belt Tensioner
    Junior Member Backyard Mechanic KARNAGE's Avatar
    Default Timing belt Tensioner
    Hi all got a problem the other day when i fitted the timing belt back on to the blacktop. I fitted the new toda timing belt and when i put the tensioner back on it seamed to be ok but over night it loosened off quite a bit. There was no problem with it before i pulled the engine apart so i am stumped. Does anyone know why it would just loose tension?
    Default Re: Timing belt Tensioner
    The bt tensioners are hydraulic right? I have been told they can be problematic. Will try and find more info....
    New Zealand
    yes the black top ones can fail
    imo you MUST replace them everytime you do the belt.
    toda belt? how much that sting you?
    please, no more PMs!
    queensland
    those tensioners can collapse if you have pressed them together too quickly, like in a big press. being hydraulic, they take ages to compress to reinstall the lock pin.
    done correctly, there is no problem with them and I've done heaps. if you've buggered it, its expensive, as it does not fit any other Toyota model I've worked on
    New Zealand
    $55rrp here in nz.
    Negative Reputation Domestic Engineer Howieau's Avatar
    Replace it. Mine was fine when I took it off (3sgte engine), then when I reinstalled it it had some freeplay. Its really not worth risking, you're best off getting a new one seeing as it has loosened off on you overnight, sounds like its no good.
    "There is a better way to do it, find it" -Thomas Edison
    Yep, replace it. I had a brand new blacktop tensioner fail after 5000km. I actually shimmed the pivot bolt for the pulley so it could lock in place while I was waiting for another new one to arrive from Mr Revhead.
    Feb 2007
    Timaru
    I have had a brand new one fail too.
    The engine builder assembled the engine and the brand new one out of the box just did not have enough tension,
    so we ordered a new one from toyota overnight and the next day the new one had heaps more tension.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
  1. Replies: 47
    Last Post: 23-10-2020, 07:38 PM
  2. Replies: 38
    Last Post: 15-07-2012, 08:49 AM
  3. Brand new timing belt tensioner installed - looks unusual (pics)
    By Howieau in forum Tech and Conversions
    Last Post: 06-10-2007, 07:56 AM
  4. Belt tensioner / nevo equivilent / bearing
    By TooF in forum Tech and Conversions
    Last Post: 17-05-2007, 07:37 AM
  5. 2JZ Timing belt tensioner probs etc.
    By 2JZR31 in forum Tech and Conversions
    Last Post: 29-08-2006, 10:32 AM
