Results 1 to 8 of 8
Thread: 4a generation Air Flow Meters
    working hard Backyard Mechanic
    Default 4a generation Air Flow Meters
    Hey guys my 4AGZE AFM has shit itself and its seeming to be very hard to find a replacement. I would like to know if any 4a versions have the same AFM as the 4AGZE with plug to suit.. 20v bigport adm etc
    Or if there is any other AFM from other toyotas that will fit and work with boost.
    Not trying to be a Carport Converter
    Jan 2009
    Default Re: 4a generation Air Flow Meters
    what car?
    Which 4agze?
    more info needed..
    But heres the reference page for 4a-gze's at club4ag.com
    http://www.club4ag.com/faq_and_tech_...-GZE_specs.htm
    but yeah need more info on what car/which motor it is, otherwise it's a guess....
    The car wouldnt matter , its a 4agze ae92 dli AFM version i am pretty sure the aw11 4agze with dizzy would work but good luck finding one of those to.. I am wanting to use a replacement to see if my afm is poo
    Achin' 4 some tyre bakin' Backyard Mechanic
    still an ST162, dude. i put an ST162 afm on exactly the same motor; same dimensions, same plug, and it started first hit.
    wiso should be credited;
    http://www.toymods.net/forums/showth...t162+4agze+afm
    he says there is a difference in piping size in his posts, but i found that the dimensions of the ST162 afm body and the 4AGZE afm body were identical. remove one, fit the other, no modifications needed.
    Johnny Cash is my Navigator.
    Quote Originally Posted by reece12
    ...if there is any other AFM from other toyotas that ...will work with boost.
    Are you blowing through the AFM? Why would boost make a difference? An SC'd 1.6L sucks from atmosphere through an AFM just like an NA, just more.
    Toymods Club Member
    Auckland
    i ran my 4agze afm as blow through on a turbo setup with no problems, jsut drilled 3 1/8th holes in the black plastic cover
    this is my setup when i finished the conversion 1 year ago worked perfect for 133kw on 10psi
    http://www.youtube.com/watch?v=llY4e...e=channel_page
  1. Air Flow meters
    By greenmac80 in forum Tech and Conversions
    Last Post: 07-09-2008, 10:15 PM
  2. 1JZ Fuel Pressure Regulator Limits
    By beasht in forum Tech and Conversions
    Last Post: 19-04-2008, 06:17 PM
