Results 1 to 4 of 4
Thread: Air Flow meters
    Mar 2008
    Default Air Flow meters
    Hey i have just purchased a 20v airflow meter and it is massive.
    hard to fit somewhere neatly.
    now the question is... can i used an earlier 16v one on my silvertop? or won't it work?
    or are there any other iinterchangeable AFM's i can use!
    Default Re: Air Flow meters
    What car is the 20v in/going in? Picture of the airflow meter would be good. I've not seen a 20v afm first hand, but there shouldn't be any reason for it to be bigger than a 3SGTE afm, and they're not huge.
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Most 16 valve 4AGE's have MAP sensors. These won't work with your stock 20V ECU. Any 16 valve 4AGE that has an AFM will be the basically the same size.
    I don't see how it doesn't fit neatly. It fits inline with the air piping like any other AFM. Where else would you put it?
    Mar 2008
    its going into a ke55 corolla.
    by the time you make the plenum and install rad and fans and overflows etc.
    there isn't much room to do it neatly.
  1. 1JZ Fuel Pressure Regulator Limits
    By beasht in forum Tech and Conversions
    Last Post: 19-04-2008, 05:17 PM
  2. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
  3. Head flow thread, please post for all to see
    By Mr DOHC in forum Tech and Conversions
    Last Post: 19-01-2006, 05:41 PM
