Results 1 to 4 of 4
Thread: idle issues in ma61-7m
    Junior Member Backyard Mechanic Azzamk2's Avatar
    western aus
    Default idle issues in ma61-7m
    after we finished the conversion the car doesnt wanna idle under 1900rpm+ im thinkin i haVnt wired something up or in that area.. the ICV is clean soo its not that any other ideas?
    Default Re: idle issues in ma61-7m
    Does the ISCV tick shut when you turn it off? It may not have power and may be open.
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Is it a cressida harness? If so you probably havn't wired power to the ISCV. In the following link is the connectors on the cressy harness. The First plug has the power for the ISCV, pin 1. This needs to be connected to the EFI main relay. Splice into the +B pin on the 22pin 7m ecu plug.
    PM me if you need more help.
    http://homepage.mac.com/rib_feast/Cr...connectors.pdf
    1994 GZX90 Mark II 1GZ-FE V12
  1. High Idle - 7M Junk
    By Adash=P in forum Tech and Conversions
    Last Post: 24-09-2008, 09:57 AM
  2. RA28 1jzgte Very Strange Idle and Running issues
    By 77GZE in forum Tech and Conversions
    Last Post: 19-02-2008, 05:44 PM
  3. high idle with 7mgte
    By jimmmayyy in forum Tech and Conversions
    Last Post: 23-01-2008, 07:12 PM
  4. 7M-GE idle control valve?
    By orestes in forum Tech and Conversions
    Last Post: 23-12-2007, 08:00 AM
  5. 1ggte wont idle :(
    Last Post: 18-12-2006, 05:41 PM
