Results 1 to 4 of 4
Thread: High Idle - 7M Junk
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    Default High Idle - 7M Junk
    In the morning, it idles at about 1200. Once it reaches normal temp, it goes up to 1400.
    I'm gonna try and clean the TB and ICV tomorrow but could a temp sensor be stuffed?
    Thanks
    AE93 SX - Thrasher 20V
    JZX100 Chaser - Daily 1J lovin
    vic
    Default Re: High Idle - 7M Junk
    Well you refer to it as junk so just throw it out then .
    Dave
    clean iscv good and proper, reset ecu, start.
    Then look for the vaccum leaks you have.
    RA23 - Twincharged
    JZZ20 - Daily
    The TPS has to be setup correctly for the ISCV to work.
  1. beams redtop idle too high
    By aw11man in forum Tech and Conversions
    Last Post: 29-05-2007, 10:59 AM
  2. Point of AFM idle screw?
    Last Post: 27-02-2006, 08:47 AM
  3. Idle issues
    Last Post: 23-10-2005, 09:54 AM
  4. High 4AGE Cold Idle
    By toaster in forum Tech and Conversions
    Last Post: 23-10-2005, 03:08 AM
