Page 8 of 10 FirstFirst ... 678910 LastLast
Results 106 to 120 of 141
Thread: RWD 1MZFE Has anyone actually done it?
  1. #106
    Junior Member Grease Monkey RA40-Rossco's Avatar
    Newcastle, NSW
    Default Re: RWD 1MZFE Has anyone actually done it?
    now for part 2 of the starter mission, will it engage the flex-plate/flywheel or need spacing
    Toyota AE93 Corolla 20v Silvertop
    BF Mk II Xr6 Turbo Ute (tickled to 316kw)
    Datsun 180sx turbo
    Forester GT
  2. #107
    yeah engages any no spacing required from what i can see..
    now one tricky part re starter.. the wire that comes from soliniod to motor runs into the block.. so need to move the cable i took back off starter and looks do-able..
    1996 FZJ80 Landcruiser.
    Email : [email protected]
  3. #108
    wa
    what bearing did you use for the input support? i had a 6021 (same as 1JZ) in there but it wasnt that deep. 12mm deep from memory.
    i cant say im a fan of the material taken out of the block, i think boosted motors will have a problem with that scenario given it is structural support for the main bearing.
    My Corolla ! - 4AGTE
    KP61 - 4AGE
  4. #109
    That's not a structural support for the main bearing, it's now merely a part to shield the flywheel from the outside world.
    In it's original application, it is beefy because it needs to hold the gearbox up, the only other support for the V6 box is at the other end.
    Similarly for the 3S, it's beefy because it needs to transfer all of the engine's weight to the gearbox because this is where the engine mounts are.
    If you think that metal removal is drastic, you should see what we're doing to one so that the GT4 box fits (ie hacking into the webbing of the block itself).
  5. #110
    wa
    well i wouldnt be taking material out of my block thats for sure. how many 1mz's have you built ? because ive only had experience assisting in the build of one thats only putting out about 600 at the wheels.
    edit: and just something i thought of, the v6 starter will be off a FWD? wont it spin the wrong way ??
    KP61 - 4AGE
  6. #111
    Have you broken one in that spot before?
    I'm sure that 600+ requires all the help it needs. More stress on the motor requires more integrity to hold it together.
    Something less powerful won't need as much to stay together.
  7. #112
    Quote Originally Posted by Adsport View Post
    this may be really stupid noob question re starters, but if you wire them reversing the poles, do they spin backwards as well?
  8. #113
    I'm pretty sure in the other thread, Joel has mentioned that he's using a V6 4Runner starter, so that's in a RWD config to start with.
    Dylan, the motor may spin backwards, but the mechanism that makes the starter gear come out to engage with the flywheel only works one way IIRC.
  9. #114
    wa
    in theory yeah but reversing polarity on electric motors heats the field coil up bigtime.
    ah good point, and i didnt realise that it was a RWD starter
    KP61 - 4AGE
  10. #115
    Yeah it is a rwd starter motor..
    Regarding the material removal from the block.. hey it's all a unknown attempt this swap.. I hope it works, if it doesn't and something fails then i've learnt a lesson and can re-asses different ways to do it.
    I didn't think I had removed much at all in the way of the strength though, the thick sections that span from the rear main area haven't really been touched, just some of the webbing inbetween..
    We'll see
    This isn't a 600hp engine either.. My aim is around 350hp..
    Joel
  11. #116
    Not so much progress today. Engine mount on driver side of block has been done. Yseries bellhousing makes gearbox lean on a 5 deg angle or there abouts so had to modify gearbox xmember to suit.
    Block off plate for egr is done.
    So tomorrow hopefully get mounts on engine xmember.
  12. #117
  13. #118
    south australia
    joel, can i ask what tool(s) you used to cut that big hunk o metal plate?
  14. #119
    Newcastle, NSW
    wow you make that look nearly too easy, what engine mounts are you going with?
    Datsun 180sx turbo
    Forester GT
  15. #120
    Angle grinder followed by die grinder followed by flapper disc.
  1. Camry 1MZFE to VVTI?
    By birdie in forum Tech and Conversions
    Last Post: 17-10-2007, 12:38 PM
  2. 1mzfe camry oil leak
    By too_quick in forum Tech and Conversions
    Last Post: 22-05-2007, 04:26 PM
