FWIW: I run a single 3/8 line with no supply issues. I do run 2x 044 supply pumps though.
Avoid the exhaust? And allow for things to move and that... Dont put it where the diff or tailshaft 'might' hit the floor etc...??
Just thoughts, otherwise i dont know...
Jase
Thanks 30psi_4agte, I'm pretty sure 3/8 is going to be more than enough for me but like everyone is saying - if I'm going to the trouble of running new lines may as well do it with room to move!
I've just been going through your build thread to try and grab some ideas. I might use flexible line to go over the diff arch rather than try and make the hard line fit!
OK, what I learned - 3/8 bundy tube sucks arse at trying to get anything close to a tight bend, it just wanted to kink. I ended up grabbing a 3m length of 10mm alloy tube from Bunnings and it was much better work with!
is it a thick wall anealed tube? hope so otherwise it will probly split which could make for a very bad day in the future.
Originally Posted by WHITCHY
Its quite thick walled - I'd assumed its annealed, it bent quite easily and was a lot easier to work with than the bundy tube. I had read about someone else who had used it on this forum but cant remember who it was.
