Results 16 to 22 of 22
Thread: Auto gearbox slightly backward when in "D"
    Perth, WA
    Default Re: Auto gearbox slightly backward when in "D"
    yeah just replaced the auto tranny fluid and still the same problem. its not steep at all, just small slope..
    did you put enough back in? ie are you checking the level under the correct conditions? have you got airlock in the cooler or something?
    Perth, WA
    it was done by a reputable automotive repair/service shop but i don't mind to check it again. how can i check the automatic tranny fluid?
    should be in your service manual. or even owners manual
    Junior Member Backyard Mechanic greywolf's Avatar
    Nsw
    Quote Originally Posted by V-Na
    Fixed for you.
    Previous poster used google images, which is why I quoted it as Google Images for the fail...thanks for the fix though.
    Perth, WA
    sorry to say that it does not comes with any manuals.
    Nsw
    Lift the bonnet, find your automatic transmission. 99% of automatic transmissions have a dipstick, some don't. Find the dipstick. Go and start your car, placing the car in Neutral. Make sure you are parked on a flat, level surface while you are at it.
    Pull the dipstick, give it a wipe. Re-insert the dipstick, and pull it clear. Make sure you are in good, strong light, as sometimes the fluid is quite hard to see. You may need to wipe your finger down the dipstick if you can't see the fluid. Check both sides, take your reading from the side with the lowest level.
    It should read between the two levels (usually reads cold at the bottom and hot at the top). Don't worry about it unless the levels are below cold, or above hot markings.
  1. W58 into TA22 Celica
    By sillycar chick in forum Engine & Driveline Conversions
    Last Post: 09-09-2014, 01:18 AM
  2. Verifying a w58 gearbox
  3. AE86 Gearbox Conversion Options
    Last Post: 20-03-2006, 01:30 AM
  4. 5M-E Auto gearbox problems
    By mic* in forum Tech and Conversions
    Last Post: 09-03-2006, 09:27 PM
