Results 1 to 15 of 22
Thread: Auto gearbox slightly backward when in "D"
    Perth, WA
    Default Auto gearbox slightly backward when in "D"
    guys, sorry for the title as i don't know how to describe it in short hehe...
    i just purchased a Toyota RAV4 SXA-11. it has 3SGE-BEAMS version and its mated with automatic gearbox.
    when it on a slightly slope road, it tends to go backward even the gearbox in "D". this never happens to my other automatic geared vehicle. how can i rectify this problem?
    Default Re: Auto gearbox slightly backward when in "D"
    Dood, this happens in some cars. (The new commodores do it for example).
    Nothing to worry bout, just gotta keep it in mind when on hills.
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    Handbrake
    AE93 SX - Thrasher 20V
    JZX100 Chaser - Daily 1J lovin
    Junior Member Backyard Mechanic V-Na's Avatar
    Hill start?
    Nov 2007
    I'd imagine all automatics would do this to some extent, depending on the car and the hill.
    Just use the brakes.
    Mar 2008
    inner west syd now!
    worn stallie??? not engaging enough at low rpms??
    Perth, WA
    that is what i'm trying to find out mates. when i came to a stop at a slightly slope road (traffic stop), i have to step on the brake or apply slight throttle to keep the car static or else it will just moving backward, even the gearbox still in "D" and the engine idling nicely..
    Carbon neutral Carport Converter Jt_70R's Avatar
    in between your engine and automatic is basically a fluid coupling, ie. the two are not connected with an actual solid shaft. try doing some quick googling for 'torque converters' and 'fluid couplings' to get an idea. hard to explain the concept neatly (and shortly) here.
    anyway, short story, what you describe is perfectly normal, the few extra RPMs you have to give your car balances out the torque on either side of the fluid coupling, hence keeping the vehicle stationary. perhaps you might need to bump up your idle speed a tad, if you find it that much of an issue?
    Quote Originally Posted by Jt_70R
    And if you don't mind using more petrol.
    Junior Member Grease Monkey DoctorDubb's Avatar
    May 2006
    Quote Originally Posted by CHB
    Last time i checked i thought this the point of having brakes?
    Torque Converter from Google Images:
    1977 RA28 with 1GGTE - Now Driveable! Just with speed holes and no doors
    Junior Member Backyard Mechanic greywolf's Avatar
    Nsw
    Quote Originally Posted by DoctorDubb
    Google images FTL, automatics don't use flywheels. I used to work in an Auto Trans shop, and the first time I used flywheel as the terminology I had my head bitten off. And for the life of me I can't recall what it's meant to be called !!!!
    Drive plate maybe ???
    Quote Originally Posted by greywolf
    Howstuffworks FTL, automatics don't use flywheels. I used to work in an Auto Trans shop, and the first time I used flywheel as the terminology I had my head bitten off. And for the life of me I can't recall what it's meant to be called !!!!
    Fixed for you.
    May 2006
    Ok so the terminology isnt the best, it was more to show the guy a rough idea. It was the first or second google image that came up just incase he was too lazy to search, back to my work now .
    Steve
    South Austrlia
    Flexplate?
    Feb 2007
    Timaru
    Auto flywheel is called a flexiplate,
    and have you checked the fluid level?
    I dont believe it is normal unless the hill is pretty steep.
    I drive customer cars every day so driving different stuff all the time,
    and cant remember any normal auto's doing that.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
  1. W58 into TA22 Celica
    By sillycar chick in forum Engine & Driveline Conversions
    Last Post: 09-09-2014, 01:18 AM
  2. Verifying a w58 gearbox
  3. AE86 Gearbox Conversion Options
    Last Post: 20-03-2006, 01:30 AM
  4. 5M-E Auto gearbox problems
    By mic* in forum Tech and Conversions
    Last Post: 09-03-2006, 09:27 PM
