Results 31 to 45 of 47
Thread: 1UZ Manual
    Default Re: 1UZ Manual
    You could have asked me before I put it back in...
    Penrith BC
    do'h ........
    ../delete/ban
    tech moderator
    New Zealand
    Fair enough, but for piece of mind and a couple of hundred bucks I'd rather get a billet flywheel.
    I would agree with you, but there are some tight bastards out there.
    New Zealand
    If you are looking for a serious race setup, the one he uses in his own car may be of interest to some.
    Factory flexplate, only used for ring gear for starter
    Tilton triple place 5 1/2 inch clutch
    custom flywheel just large enugh to fit clutch.
    Very similar to this pic I posted in another thread, around $1,500 NZD but not very streetable.
    CD is for scale.
    Callum
    Junior Member Backyard Mechanic manny's Avatar
    This is the prototype of the kit that Neil at RUSH Imports is doing.
    Should be up and running in his Soarer by Easter.
    It's designed to maintain/use the standard pull type R154 clutch on a supplied custom billet flywheel
    I'll know more once the prototype is thoroughly tested and costed out.
    GSE20 IS250 - daily
    Do you know what pricing will be like with this kit? And also, will it be availible for W series boxes?
    Also, is it possible to turn an auto flywheel into a manual one by affixing a friction surface to it? Doesn't seem like the wisest idea, just wondering if it's been done...
    Cheers, RM.
  8. #38
    Today Im a Domestic Engineer Enchanter's Avatar
    Tas
    I agree, I don't think some people understand how bad it is for the flywheel to die at 7000 rpm !!
  9. #39
    Quote Originally Posted by mullett
    No pricing yet.
    Yes, it should work with a W5x box, but only if you have a JZ bellhousing on it.
    Should also work with a V160 too.
    And don't even think about it.
  10. #40
    Junior Member Grease Monkey Bored?'s Avatar
    When an adapter plate is used, how is the extra space adjusted for between the input shaft and crank?
    Is it a simple matter of the input shaft splines being long enough to accomodate a plate? Are other spacers required? Putting a spacer between the crank and flywheel would seem easiest, since the clutch slave is usually on the gearbox side, however that wouldn't leave the starter motor in the wrong place?
  11. #41
    There is no extra space.
    Mr Toyota gracefully made at the JZ bellhousings ~20mm shorter than every other bellhousing, and extended the back of the block to compensate.
    This means you can use a 20mm adaptor plate and everything lines up perfectly.
  12. #42
    Quote Originally Posted by WDE_BDY
    CD is for scale.
    Callum
    That is a twin plate clutch, not a tripple
    He also said its similar to that pic, but not that actual pic.
  14. #44
    New Zealand
    Cheers, RM.
    See the pic I posted above, its exactly what that is and race tested on an Atlantic spec 4AGE to over 10,000rpm. However note the friction surface is bolted to the crank along with the flexplate.
    Callum
  15. #45
    New Zealand
    Just to update, the inserts to fit a triple or double plate tilton 7.25" clutch are now being sold for NZ$330. Pretty good option if you were going for a serious clutch anyway.
    http://www.trademe.co.nz/Browse/List...x?id=102228217
    Callum
  1. 1uz Ms65. I Need Some Advise
    By AZZTOY in forum Tech and Conversions
    Last Post: 19-03-2006, 03:43 PM
  2. 1UZ into RA65 - Drift car.
    By nihilism in forum Tech and Conversions
    Last Post: 08-02-2006, 10:16 AM
