Results 1 to 6 of 6
Thread: ta22 auto to manual
    vic
    Default ta22 auto to manual
    if i find a decent bodied Ta22, that is an auto, how expensive/difficult is it to get a manual gearbox put in? any reccomendations...
    Classic Not Plastic Domestic Engineer ace's Avatar
    Default Re: ta22 auto to manual
    I've never done this but have considered it....
    the hardest part will be putting in the new pedal box thingo and doing all the clutch stuff....
    The T50 gearbox should bolt up to your 2T.....
    Then you might want a Manual console and badges....
    The easiest thing could be is to buy a wrecked manual TA22 with a good gearbox/clutch etc and rip all the parts out of that....
    ace
    My TA22
    Quote Originally Posted by gianttomato about new cars
    Yeah sure, it goes alright and it's got air conditioning, cup holders and automatic tampon removers, but where's the charm?
    Junior Member Grease Monkey camshere's Avatar
    Just off the top of my head - things required
    - Gearbox (duh)
    - Gearbox crossmember
    - Flywheel
    - Tailshaft
    - Diff (not a big deal but autos had different ratios)
    - Clutch
    - Clutch master and slave cylinder
    - Fluid line between cylinders
    - pedal box with clutch pedal
    - Manual centre console
    I think thats about it - Like Ace said the cheapest way to do this would probably be just to buy a semi-complete TA22 wreck rather than trying to get all the parts together. That way you can just swap the parts and you have a reference to go by. Also if you don't have to worry about missing parts.
    There may be things i've missed here - but i think thats the main stuff
    Cam Marshall
    Perth, Western Australia
    '08 E82 135i, '83 TT142 GT, '77 RA28 LT '72 TA22 LT, '91 FZR 1000, '83 GT550
    Deal with the Frog Backyard Mechanic Cool1's Avatar
    Mate there is nothing difficult about doing an auto to manual conversion in the TA22!
    You just need to source the following:
    T50 with clutch slave
    Tailshaft
    Clutch master
    Clutch line
    Brake pedal
    Clutch pedal
    Manual crossmember. This is not really required, but makes things a lot easier.
    Once you have all the above, it all just bolts in
    i just did a auto to manual conversion in my rt104 with a w50. took 3 people 2 hours was so easy just have everything you need and replace all bearing as you go mate. and you might have to change to yokes over in the talesharfts
    It's pretty easy, gather the parts and just do it! There's a neutral start switch to close but that's easy on these, the plugs are in the loom to change it back. Throw a spigot bearing in the end of the crank too
    The shifter hole will have to be cut further forward, and a plate welded/riveted in at the back of it.
  1. from auto to manual?
    By suss_slide in forum Tech and Conversions
    Last Post: 12-03-2007, 03:31 PM
  2. Ma61 auto to manual conversion
    By Mattrt142 in forum Tech and Conversions
    Last Post: 22-02-2006, 07:13 PM
  3. 1GEU > MTEU + Auto > Manual in GA61 swap
    By KwS in forum Tech and Conversions
    Last Post: 06-12-2005, 01:36 PM
