about the only welds will be the tube that the clutch cable goes into on the firewall (if it is not present) and probably drill the firewall out there too...Originally Posted by suss_slide
and you may need to cut a new hole in the transtunnel for the shifter.
as the KE30's were often traumatics, you might want to check that the rear cross-member fits, or else grab a donor one...
and tailshaft..... different (iirc)
other than that, straightforward.
