Results 46 to 60 of 72
Thread: 3SGTE rattly on low revs + when cold only ** problem found **
  1. #46
    cease striving Conversion King RobST162's Avatar
    Default Re: 3SGTE rattly on low revs + when cold only ** now with audio**
    ok, have replaced the timing belt idler pulley, absolutely no change, noise is still very loud
    as for moving parts I'm left with oil pump and big ends
  2. #47
    wa
    in all honesty the video makes it sound like bearings to me.
    the stock oil pressure guage is usless. in the st184 i had i screwed the big ends and the oil pressure light never came on, when i checked oil levels i drained less than a litre from the sump.
    but yeh i dunno why the sound goes away when warm.
  3. #48
    plenty of oil in the car, recently changed, doesn't use any
    but i'm running out of alternatives!
  4. #49
    Depress the clutch pedal and is there any change to this noise?
  5. #50
    yeah.. already did that
    going to take the sump off tonight I reckon
  6. #51
    Fear the Rapeodile Carport Converter blakeg's Avatar
    May 2006
    ohh man , that sux,,,, i now hope its not the bearings for ya.
  7. #52
    cruisin in a z30 Automotive Encyclopaedia -=DV=-'s Avatar
    i hate to say it mate..but my last 3sge went in exactly the same way..started with a knock down low when cold..then it got louder and gradually stuck around for longer and further up the revs...i continued to drive it into the ground for another 2000ks or so until it finally had enough and i put another 3s in lol
    JZZ30 Soarer
    wow....only one toyota now, at one point i owned 6....whats happened to me :S
  8. #53
    hmm after I JUST had the engine out for the new clutch.
    I have to drive to melby in 1 week. I wonder if I might be able to put some new big-end bearings in just with the engine in there (it's got great compression no need to rebuild) if that turns out to be the problem.
  9. #54
    Nov 2007
    ROB: If its a knock you will need to get crank to a machine shop man. maybe take a rental car to melbourne.
  10. #55
    Nov 2007
    pull you sump off and have a look at your oil for metal shavings. wiggle the big ends and feel for movements
  11. #56
    Rob, if it does end up being big-ends and they haven't scored 'that badly' or are visbly ok, you can replace just that bearing in car with the sump off. im not a fan of it but i had to dono1 main bearing on a 40,000km old 320cdi benz the other day. And guess what, factory fix is this way. So if the best manufacturer of vehicles in the world says its ok, i dont see why not
  12. #57
    thanks stu that's some genuinely good news
    right, well tonight's update
    just had the timing belt off and feeling the oil pump and it wasn't a smooth motion at all compared to the spare one I had on the wrecked block of the white celica (sitting here in the carport)
    so moved the pump pulley assembly and gear over, primed it, put all the timing back on and started it up
    the consistent tapping/knocking is gone! but not completely. how crazy is that. There's some definite wear in the old one, but nothing to make me think it would have stopped.
    that said, the new sound is an intermittent 'miss' if you will accompanied by a nice little 'knock' - i'll record it tomorrow and post it up
    by the oil pump has a much freer feeling motion now, but that may have been the bearing/seal :?
  13. #58
    Default Re: 3SGTE rattly on low revs + when cold only ** problem found **
    I wonder if this might have had anything to do with it
  14. #59
    ouch..
    crank ok?
  15. #60
    i bite my fingernails so it's very hard to tell, no big evident grooves
    i haven't taken any others off, but #1 (this) is usually the worst
    i'm sure praying so though
  1. 3sgte Limits???
    By Douglas Black in forum Tech and Conversions
    Last Post: 30-11-2013, 10:33 PM
  2. pressure tested and problems
    By 2revup in forum Tech and Conversions
    Last Post: 18-02-2008, 03:11 AM
  3. 4AGZE revs like crazy on cold start
    By Drifty Midship in forum Tech and Conversions
    Last Post: 18-11-2007, 05:43 PM
  4. Replies: 10
    Last Post: 22-01-2006, 02:58 PM
