Page 1 of 4 123 ... LastLast
Results 1 to 15 of 57
Thread: Which engine to use.?
    Old Fart Backyard Mechanic dale30's Avatar
    Casino nsw
    Default Which engine to use.?
    Hi All
    For those of you that dont know me ..We race an XT130 on the speedway..
    We are currently running an 18R but it is no longer competative.Its gone from the front to mid pack So the question is which engine to repower with.
    Here are the choices that my sponsor Bruns-Byron Wreckers have.
    Early 4AGE ( AE82 88?KW ) ..........one only ( good condition )
    2S from ST141 ................. a couple
    3SFC Camry/Apollo ...............dozens of these in all variants
    I would assume that a 4A rwd gearbox from KE 70 or some as such thing would work.
    I have also been led to believe that a 2S from ST141 will fit 3S.
    As we run flat out in second gear, no gear changes or slowing down much KW's are not every thing.. usable revs = track speed.
    18R is only runnung about 6400 and no power to pull another gear...we need to be able to get to 7000
    4AGE must remain totally stock.
    2S can have big head shave any cam and any downdraft carby.
    3S remain stock except any downdraught carby.
    We had a ST141 racing with us a couple of years ago and it was pretty quick.
    Will the 3S happily rev.?
    What do you all think.
    XT130 speedway car XT130 road car
    2 x Renault Fuego speedway cars
    02 TS50 falcon
    Light travels faster than sound. This is why some people appear bright until you hear them speak
    Default Re: Which engine to use.?
    http://en.wikipedia.org/wiki/Toyota_S_engine
    ST141 2S = 157Nm, but with compression and rast lift fat cam, should be a fair bit better.
    3S, less than 170Nm but carby and manifold would help? still cam limited...
    comes down to if a modifies 2S, with nasty cam and high comp, and good carb... will be better than a pretty much stock 3SFC... since they are both 2L, i'd be guessing the 2S
    the 4A, while it will rev, is torque limited, and nothing you can do about it...
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    Sorry but all those engines besides the 4AGE () are rubbish
    The 4AGE is good in light cars like Corollas but the Corona needs something with cubes.
    Need a motor with torque. If you can get your hands on a 22R and if the reguations allow it, that would be a good choice.
    If your stuck with the choices above, I guess the 2S should do the job and would be the easiest as it RWD already.
    AE93 SX - Thrasher 20V
    JZX100 Chaser - Daily 1J lovin
    Casino nsw
    Quote Originally Posted by d-master
    Yep the corona is fairly heavy every thing striped out but then full full cage and front and rear bar work.that was my worry with the AGE
    Restricted to 2ltr unfortunatly..so 22R wont do.
    02 TS50 falcon
    Casino nsw
    Thats what i was thinking but 16 vavles and 2 cams is good for revving.
    hard decision.!!!
    02 TS50 falcon
    Casino nsw
    3S-FC 87-91 86.0 mm 86.0 mm 9.8:1 1998 cc 85 kW@5600 rpm 166 Nm@4400 rpm
    Thats buckets better than 18R..then add bigger carby and exhaust.?
    Will 2S gearbox fit 3S as i was told..
    wreckers also has a couple of ST162's as well.
    02 TS50 falcon
    18RG not an option? Would be an easy swap and I'd think the mod list you'd be allowed would be quite large?
    Assume you have 18R atm?
    Wilbo's JZA80
    Wilbo's JZZ12
    Casino nsw
    Hmmm Sore point.!!!
    had an RGEU in it for one meeting with a 2" su grafted onto the manifold..had issues getting it rich enough causing backfiring...Bad tempered daughter threw the clutch and gave it a BIG.!!!! rev ( to clear the plugs ) doesnt like not winning !!
    Everyone watching over the fence said it was about 9500 for about 5 seconds.
    Spun bearings then jumped timing chain.... No money to rebuild.
    02 TS50 falcon
    i know of a built 21r 2000cc race motor that you may be interested in, cross flow has to be better than the 18r design.
    well.. regardless of how good a 4AG is, they are still fairly shit stock, and will be SLOWER than either the 2S or 3S at a given RPM as they have LESS torque
    easy for the 4A fanbois to forget that
    given that two engine have to stay basically stock, and one can have a stupidly big cam and higher comp.... i kno which i would choose
    as you say, 16valves and 2 cams is good for revving
    BUT
    you can7t change the cams to take advantage of that, so it will fall over at the stock revs of what? 6000rpm? where to stock peak torque is.
    the cam/s control the character of the engine. and two choices have stock cams (and one of those is down about 20Nm on the others to begin with!)....
    if you could swap cams, then 3S for sure. but with stock cams in 3S, and lumpy cams in 2S......
    Casino nsw
    Quote Originally Posted by old_school_jap1
    HHMMMM..Another thought..
    21 head and front go straight on 18.????
    Do 21's have decent head..will they rev.???
    my 18 is race built so a good head might be easier....
    02 TS50 falcon
    Casino nsw
    BUT
    Will the 2S take constant big revs.??
    02 TS50 falcon
    if you build it to... why not? if it has bucket problems, go shim under or shinless..
    rods? get nice bolts...
    etc...
    depends how much you can change and budget, but.. a high ramp rate, large lift cam will likely get you better mid range as well as better top end, than a dead stock same size motor with a new carby...
    try both
    get a 3S and put on new carby, race it for a bit, whack it on dyno.. and wile running it, get 2S and get a cam ground.. chuck it on dyno.. see how it goes.
    Nice..... Grease Monkey Rex_Kelway's Avatar
    Rex knows this is going against the 'fingers in the ears shouting "Toyota, Toyota, Toyota!!!"' theme of this forum but perhaps the wrecker could find you out a Holden 304/308 manual package?
    You may have to stick to the same manufacturer, but if not, bang for your buck the simple carb'd V8 would be pretty good. Nice reliable, solid, usable power and replacement/tweaking parts up the wazoo...
    Rex Kelway Sucks - Fabrication thread
    Rex Kelway - ABN: 41 267 379 001
    Fabrication, Manifolds and CAMS spec Roll-cages in SA...
    can you destroke them far enough?
  1. Sams MA61 7MGTE Conversion Guide
    Last Post: 07-07-2015, 11:12 PM
  2. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 06:27 PM
  3. MA70 --> JZA70 Conversion
