Results 31 to 45 of 57
Thread: Which engine to use.?
    Old Fart Backyard Mechanic dale30's Avatar
    Casino nsw
    Default Re: Which engine to use.?
    I was also told that the Injected 3S was better balanced compared to the FC is this true.
    XT130 speedway car XT130 road car
    2 x Renault Fuego speedway cars
    02 TS50 falcon
    Light travels faster than sound. This is why some people appear bright until you hear them speak
    Casino nsw
    Anybody know what starter,flywheel etc: are needed to fit the ST141 box to 3S motor.
    Is there any reason why with a sump mod the 3S cant be stood up straight.
    02 TS50 falcon
    Nothing really stopping a 3S from standing up straight. Modify sump and pickup, ensure the oil drain from the head isn't an issue.. no worries.
    As for the starter and stuff.. whichever is lighter I guess. Can't remember if the 1st gen 3sge is 6 or 8 bolt crank/flywheel.. Surely someone else can chime in.
    just wondering why the 21r idea died? it would bolt up to the gearbox you run currently (i think) and mounting it wouldn't be a problem.
    Casino nsw
    Quote Originally Posted by old_school_jap1
    I could get 21R head and timing case bits and put onto my motor But is that going to give me a higher rev range.do 21R's have flat tops or dished pistons.
    My 18R has 3 angle vavle job 60 off head and 30/70 cam 60 up flat top pistons,decked block and wont pull past about 6200.
    02 TS50 falcon
    Quote Originally Posted by dale30
    21R's have domed pistons. Open combustion chambers.
    Your 18R must have been limited somewhere. Port flow, manifold/carby, ignition breakdown, could be a number of things.
    Casino nsw
    Quote Originally Posted by ViPeR_NiPPleX
    21R head is not an option then..
    18R is limited by sh#t head flow..
    02 TS50 falcon
  8. #38
    or valve bounce?
    (might wanna trim your sig before River sees it )
  9. #39
    Casino nsw
    or valve bounce?
    Wish it was valve bounce but...runs perfect just wont pull past 6200 under full load..
    theres only so much an an old 18R can do..
    02 TS50 falcon
  10. #40
    Jul 2007
    If you can get a 3S-GE in there I would go that past any other that has yet been proposed. To convert to rwd you need to use a 2S-C bellhousing off an SA63 celica etc.. that's all i know lol sry
  11. #41
    8 bolt, like the rest of the 3SGE's.
  12. #42
    Jan 2008
    queensland
    why not a 3sfe out of a rav4
    2l bottom end and what looks to me to be the 5s head
    may have more torque? being a (cough) off roader
    or the computer out of the 3sfc that controls the ignition only on the 3sfe with 38/38 webber
    2009 aurion
    Purple 2000 Hilux - 1UZ
  13. #43
    Casino nsw
    Quote Originally Posted by litldv8
    That sounds interesting..Im going to the wreckers today so i will see what models they have got.
    02 TS50 falcon
  14. #44
    Casino nsw
    Yum Yum i have just seen my first GE..I just love those Yamaha heads. Now big problem..Where to find a manifold that i can modify on to it to run a carby.
    Is there a difference in the bottom ends of the 3 different 3S motors..FC FE GE.?
    Is one of them better than the other.My wreckers has about 12 FE's and 2 GE's in 162 celicas. both of these have BHG's. Do these heads crack easily.?
    02 TS50 falcon
  15. #45
    Casino nsw
    I scaled the corona with 18R up today and was surprised how light it was 1069kgs considering that the AE92's with 4AGE's that we are chasing are 1150kgs.
    4AGE should be able to pull Corona..
    What gearbox do we use for rwd coversion
    02 TS50 falcon
  1. Sams MA61 7MGTE Conversion Guide
    Last Post: 07-07-2015, 11:12 PM
  2. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 06:27 PM
  3. MA70 --> JZA70 Conversion
