Results 1 to 15 of 29
Thread: 1jz-gte relays and tech info and help
    Slanted Photographer Automotive Encyclopaedia LeaThaL's Avatar
    Aug 2006
    Default 1jz-gte relays and tech info and help
    hey all
    im trying to get my 1jz started today but im having some issues, im not totaly sure what its doing yet but as far as i know im not getting any fuel pressure, i dont know if its cause its not getting power or what but im getting no fuel to the engine, its only got 5 Liters as i emptyed it when it was sitting so its got fresh fuel now but yeah
    is there a way to just prim the fuel pump or to tell if its even running?
    also im yet to put a bridge wire from the factory 7m alternator lead to the 1jz alternator as i was told that i shuold try it first to see if when i connected the loom to the body loom, that it might of been a part there but im thinking ill do it now so i have a length of auto eletronic dudes approved wire, should i just connect it to the usual point with a loop and bolt them together and then just put aonother loop on the other end and put it on the alternator as normal?
    1 G L O V E
    88 Ga70 supra --- Under powered and over cooled Daily
    Default Re: More 1jz-gte inital startup Questions
    Quote Originally Posted by LeaThaL
    hey all
    I had a similar problem, in my case 5 liters was not enough.. Go grab another 5 liters and put that in.
    With ignition on you can bridge FP and B+ pins @ the check connector, that should get the pump started, and without the engine running you should soon hear if the fuel is pumping.
    good luck
    Aug 2006
    Quote Originally Posted by mr2gze
    bugger!! ill have to run down and get some more now
    thanks mate
    1 G L O V E
    Aug 2006
    where is this check connecter?
    1 G L O V E
    Junior Member Backyard Mechanic Hash_ra23's Avatar
    should be on the side of the intake plenum..next to where the oil dipstick comes up
    1977 RA23 Celica -> 1ggte conversion [SOLD]
    MA70 Supra 1JZ 5speed [SOLD]
    Current: IS200 1JZ VVTI 6 speed
    Aug 2006
    oh the digagnostic plug?
    1 G L O V E
    Junior Member Backyard Mechanic Jaemus's Avatar
    that'd be it
    if that doesnt work, its not wired up right probably, you can check the pump itself at it's plug if you feel like pulling everything apart
    and check the wiring for the COR (circuit opening relay) if you have one - its there to turn off the fuel pump when the motor isnt running (in case of accident)
    1992 MR2 GT turbo
    2009 Lexus IS-F
    Built Australia's first V6 MR2 >> Winner: "I'd Drive It" award - Toyfest '07
    Aug 2006
    well ill go check that now but either way i got some plugs now so ill get a soldering iron and clean it all up once i know its good/no good
    will go try it all again now once i find a decent wire to bridge these terminals
    1 G L O V E
    Aug 2006
    ok its official, im not gettin fuel or spark!
    im guessing i might not have any power going to the ECU so ill have to go thru tomorrow and solder and crimp up all my wiring to make sure that im getting a nice tight connection with these new navara plugs i have here so its clean and neat and i can know i have a signal and power coming thru!
    1 G L O V E
    good luck
    Sadly a lot of engine conversions don't have the wiring to a level where this will work! The smaller things like this often get skipped is the observation I've made
    Your problem sounds wiring related to me!
    WIlbo
    Wilbo's JZA80
    Wilbo's JZZ12
    Aug 2006
    WIlbo
    yeah thats what i was thinking also, and i dont have power to my ecu lol
    what wire supplys power to the ECU as i wanna check it before i start redoing it all but either way im gunna solder the wire extensions to the z20 engine plug and crimp them into the plugs and then do the same for the 1jz loom plug just so its all nice and neat and i know that their making a solid connection
    if not wilbo im contracting you with beers to help finish it
    1 G L O V E
    Which version 1JZ engine ECU do you have?
    The pinouts are different for JZZ30 vs JZA70 etc
    PS: I'm not in Bris anymore mate, so might not be the best help! lol
    Wilbo's JZA80
    Wilbo's JZZ12
    if it came out of a soarer they have a funny fuel pump controller? eg - the ecu doesn't just switch the pump directly? (foggilly trying to remember backwards)
    Aug 2006
    its a jza70 loom and i used a jza70 to ma71 set of plans and ive heard from heaps that a ma71 and a mz21 that their almost identical so it seemed pretty good but ill seehow i go with it tomorrow
    1 G L O V E
    Aug 2006
    ok so this is the story so far, 1jz turns over, gets no fuel or spark, dont have a "check engine" light so from what im told the ECU isnt getting power so this is what i did....
    armed with these little buggers, a 7m-gte plug i got off a old loom, a soldering iron, solder, wire cutters and my wiring plans i hit at it again
    for the first plug "the engine loom to ecu loom plug" i used a old 7m-gte body loom plug i cut off my old loom, i connected the correct wires and twice checked it, then soldered them giving this result....
    once finished i got this which i feel is nice enough to pass what i call "decent"
    and then i did the same for the engine to dash loom setup, checked each one twice, soldered them together, made it nice and clean, and used one of my nice new toys to get this result.....
    sooooooo IVE STILL GOT NO ECU POWER!!
    what else have i missed?, i checked them all and i still dont have a check engine light and im just famboozled now
    someone please help
    1 G L O V E
  1. w58 with 1JZ
    By hecate in forum Tech and Conversions
    Last Post: 25-07-2008, 11:24 AM
  2. 1jz to 2jz
  3. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
  4. 1jz vs 2jz heads
