Results 1 to 3 of 3
Thread: Dizzy vs coilpacks: 1G-GTE
    Default Dizzy vs coilpacks: 1G-GTE
    Ok, so the engine for the sillycar came with an EMS stinger (which will need to be re-wired) and a set of coilpacks. My question is: should I wire the EMS up with the coilpacks, or is this going to create more issues than it's worth? I'm imagining that if I use the dizzy and a coil as toyota intended, the ignition timing adjustment will be much more limited?
    -RM.
    Montrose
    Default Re: Dizzy vs coilpacks: 1G-GTE
    If the coils are anything worthwhile, and connected properly, there shouldn't be any problem. The dizzy only limits timing adjustment by mechanically how far the rotor is from the intended firing point. Say you want a range of 0-40 degrees BTDC, set the dizzy firing point to be at 20 degrees BTDC, and all should be fine.
    The 1g dizzy is suitable to act as a CAS of sorts, when programed into your after market ECU. Alternatively you can get a 1ggze CAS and they slot right in and are alot slimmer!
    RA23 - Twincharged
    JZZ20 - Daily
  1. 4AGE 100kW Dizzy Oil Leak Guide
    By Talasas in forum Tech and Conversions
    Last Post: 05-11-2014, 08:00 PM
  2. Dizzy advance degrees 18rg
    By maurice c in forum Tech and Conversions
    Last Post: 16-07-2013, 11:05 AM
  3. 18rg dizzy spins 180 degrees.
    Last Post: 21-12-2008, 07:40 PM
  4. Small port dizzy to CAS and multi-coil ignition?
    By HRV-00S in forum Tech and Conversions
    Last Post: 17-03-2008, 04:47 PM
  5. 4AGE carby dizzy setup
    By Grega in forum Tech and Conversions
    Last Post: 03-01-2008, 08:12 PM
