You can adjust the idle speed on the carb.
You could adjust the mixture screws to lean out your mixture, but that wont be good for your valves and exhaust, especially when the car is under load.
Also be sure that your running a clean filter, and that your carb is clean.
If you haven't done so, adjust your ignition timing, and check your spark plugs.
