Results 1 to 5 of 5
Thread: Tuning a stock 3k
    Nov 2007
    Default Tuning a stock 3k
    Could someone please tell me,
    * At what degree btdc should a stock 3k engine fire number one cylinder?
    * What distance is the the points gap?
    * What are the clearences for intake and exhaust under rockers.
    * Any advice on stock carby. To get a reasonable idle speed and smooth running.
    Junior Member Grease Monkey 3BarSuperstar's Avatar
    Nov 2007
    Default Re: Tuning a stock 3k
    Timing at a guess would be 10 degrees before and points gap you could probably get away with 16 thou. Have you tried looking around the net?
    Junior Member Backyard Mechanic benjamin's Avatar
    I'll be home in about 10 days (April 1st) and I am pretty sure that I have a tuning manual for the old corolla's, and should have the tune up specs. If you haven't found out by then send me a PM and I will look it up for you.
    Quote Originally Posted by celica gt-t
    10deg BTDC, but 10-15 should be ok unless you are using low octane unleaded.
    points gap.. 0.2-0.4mm.. just set for 0.3mm
    rockers, 0.2-0.3mm (maybe 0.2-0.25 for intake and 0.25-0.3 for exhaust)
    i usualy run them a bit tighterm but it depends on your cam base circle etc.. aim for 0.2-0.25mm?
    umm..clean carby helps. set the float level.. after that, it is just fiddling wiht the idle mixture and idle speed..
    new/clean spark plugs help. for stock, heat range 5 (in NGK) is good.
    Mad****** Grease Monkey FASTFOO's Avatar
    vic
    What OC said but set the timing to 15' BTDC
    Orig factory said 7 or 8 and was then revised and memos sent to all dealers stating 15'
    they go much better there!!
    Regards
    MATT.
  1. Tuning Information
    By MADcunz in forum Tech and Conversions
    Last Post: 28-05-2007, 10:38 PM
  2. 4agte - Tuning tips and experiences wanted
    By Lenso in forum Tech and Conversions
    Last Post: 10-10-2006, 10:45 PM
  3. 1JZGTE Stock headgasket...how much boost?
    Last Post: 29-12-2005, 04:40 PM
