Results 1 to 4 of 4
Thread: Longer Lower control arm - what tie rods?
    Junior Member Backyard Mechanic sleeektoy's Avatar
    Jan 2007
    Auckland
    Default Longer Lower control arm - what tie rods?
    Ok, I have fitted longer (GE sigma) lower control arms to my TA22 celica and was wondering what the options were with tie-rods for lengthening them.
    I had a look at various threads and couldn't find any options! (correct me if i'm wrong)
    The LCA's are 40mm longer per side, and the tie rod adjustment is not enough.
    The option of making new tie-rod tubes is the only one i have unless someone knows of a longer tie rod arm that would suit.
    anyone know of longer ones?
    _____________________________________________
    TA27 GT - How rare can you get!!!
    RA28 GTV daily driver
    Default Re: Longer Lower control arm - what tie rods?
    RA40 tie rod ends are your friend
    Jan 2007
    Auckland
    ok - checked them out at supercheap, it appears the RA40 are identical to the TA22 in the parts manuals.
    the only ones long enough are nissan navara ones! and i havent checked whether the thread is the same yet.
    New Zealand
    go to autolign with the tierod ends and go through boxes!
    are these rack and pinion? if so take the rackends as well as you can get longer ones as well
    please, no more PMs!
  1. ECU jzx100 pins
    By splatt in forum Tech and Conversions
    Last Post: 30-08-2011, 06:11 PM
  2. a GOOD electronic boost control
    By renxun in forum Tech and Conversions
    Last Post: 27-01-2009, 01:54 AM
  3. Replacement RA23 Front lower control arms
    Last Post: 04-01-2008, 08:03 PM
