What engine came out? It might make it a bit easier.
hey everyone,
as a lot of you know i'm building an '88 hilux with a 1jzgte out of a jzz30, so far i'm up to the wiring and have spend quite some time reading the translated wiring diagrams of the jzz30, i'm running standard engine, ecu and automatic transmission, i've put alot of time into it so far and i am up to the stage where i need help haha, so i'm hoping you guys and girls will help me out as hop[efully what i've done will help alot of you out too....
where i'm at with the wiring is the 4 plugs on a jzz30 1jzgte engine loom that go into the cabin to power, combination meter, fuel pump etc.... however there are a few wires i dont know how to connect and need some help, i've labeled every wire on the 4 plugs from were they started to were they go but like i said not bein an auto elec some is abit confusing to me, so i hope you can help, also i'm not using A/C or power steering so that eliminates quite a few wires....
C12 plug:
BLACK- from starter relay- ST(combination meter)....unsure about wiring this one??
BROWN- earth
YELLOW- nmbr#1 injector- T(combination meter)....unsure about wiring this one??
BLACK/ORANGE- nmbr#1 injector- multi display computer(multivision).....dont think i need this wire
BLUE- ABS computer(12v)- diagnosis computer......this is abs so shouldnt need it
GREEN/BLUE- ???? couldnt find this wire
BROWN/BLACK- earth
PURPLE- ABS computer(TS)- diagnosis computer.....this is abs so shouldnt need it
GREEN- CCo(from ecu)- noise filter exhaust air temp sensor....unsure about wiring this one??
C11 plug:
YELLOW/BLACK- oil pressure(combination meter)
BLUE/YELLOW- check engine light(combination meter)
RED/BLACK- AT indicator switch- reverse light(combination meter)
YELLOW/GREEN- water temp(combination meter)
BLACK- tacho
BLUE- AT indicator switch- neutral light(combination meter)
PURPLE/RED- oil level light(combination meter)
PINK/BLACK- diagnosis computer- absorber control computer(TEMS).... pretty sure dont need this
GREEN- AT indicator switch- 2nd light(combination meter)
GREY/YELLOW- VF(from ecu)- ENG(TDCL plug)
GREEN/WHITE- AT indicator switch- drive light(combination meter)
GREEN/YELLOW- TE2(from ecu)- TE2(TDCL plug)
GREEN/ORANGE- P(from ecu)- pattern select switch- ECT power light(combination meter)....unsure about wiring this one??
WHITE/RED- exhaust temp sensor light(combination meter)....unsure about wiring this one??
AQUA- TE1(from ecu)- TE1(diagnostics plug)- TE1(TDCL plug)
BLACK/YELLOW- ?????? couldnt find this wire
BLUE/RED- (3)meter speed sensor- meter check connector- check engine light(combination meter)....unsure about wiring this one??
RED- (2)meter speed sensor- check engine light(combination meter)....unsure about wiring this one??
GREY/RED- OD2(from ecu)- meter check computer- O/D off light(combination meter)....unsure about wiring this one??
GREEN/RED- TT(from ecu)- TT(TDCL plug)
WHITE- AT indicator switch- L light(combination meter)
GREY- AT indicator switch- P light(combination meter)
CF2 plug:
RED/YELLOW- ELS(from ecu)- mirror heater..... shoulnt need this wire
YELLOW/GREEN- L (on regluator)- combination meter....unsure about wiring this one??
GREEN- FP(diagnostics plug)- FP(fuel pump control relay).... we put this on tachometric relay
BLACK/WHITE- STA(from ecu)- neutral start switch- STI on ignition barrel....unsure about wiring this one??
RED/BLUE- heater fuse- A/C computer..... shouldnt need this wire
RED/GREEN- FPC(from ecu)- FRC(fuel pump control relay)..... we put this on tachometric relay
BLACK/ORANGE x2- from ignitor to IG2 on ignition barrel
BLACK/RED- B(fuel pump control relay) joins up to BATT(from ecu)....... tachometric relay??????
PINK- DI(from ecu)- DI(fuel pump control relay)....... we put this on tachometric relay
YELLOW- (1)meter speed sonsor- ignition(meter 10A)....unsure about wiring this one??
CF1 plug:
BLACK/YELLOW- ALT(on regulator)- ignition(engine7.5A)....unsure about wiring this one??
PINK- SP1(from ecu)- check engine(combination meter)....unsure about wiring this one??
BLACK/ORANGE- IGSW(from ecu)- IG fuse(7.5A)- IG2(ignition barrel)....unsure about wiring this one??
RED- IDL(engine control computer)- cooling fan computer..... dont think i need this wire
GREEN/WHITE- STP(from ecu)- stop lamp switch....unsure about wiring this one??
GREEN/RED- power steering computer.... dont need this wire
GREEN/BLACK- power steering computer.... dont need this wire
BROWN/YELLOW- ECT(from ecu)- cruise control computer..... dont need this wire
BLACK/WHITE- ?????? couldnt find this wire
WHITE/RED- ?????? couldnt find this wire
hope you can help
cheers,kern
hey champ a 22R-E came out of the toyota and the 1jzgte is out of a jzz30 soarer, also if it help i'm modding a digital dash out of a jzz30 into the hilux tooOriginally Posted by PsyCo JZX83
Have you got the body harness diagrams from the hilux?
hey mate yeah i've got the body diagrams, the hilux engine was not fuel injected so it makes it abit hard and also the hilux was originally a manualOriginally Posted by PsyCo JZX83
If it was carby it was a 22R not a 22R-E. I that case I can't help you sorry.
If it was injected it wouldn't have been that hard to work it out but I'm no guru as to how you are going to make it work if it was carby originally. I reckon you will need to make relays to turn on:
Injector Power
Coil/Igniter Power
Having just wired 90% of my own conversion I can promise you factory ecu in a conversion is a PITA. In your case I would ditch the auto and slap on aftermarket management of some description. Be a hole lot simpler. If your dead keen on keeping it auto then whack a T350 or T400 behind it.
Just my 2 cents.
ok now if you are running a standard engine there is no need to use an aftermarket ecu.
if you are using the dash from the donor frontcut alot of the colours should be the same from the engine harness to the plugs from the dash plugs on the new cluster.
toyotas use a common colour for most wires etcc..
coolant gauge, oil light/gauge, alternator light, check engine light, etc..
if you can identify these common wires you will need to run them towards the ecu (f they arnt already)
being that your previous engine was carby you will need to fit and wire a few relays for EFI (injectors, coils etc) FUEL PUMP aka circuit opening relay.
this is a starting point.
hope this hepls abit.
PROWIRE PERFORMANCE WIRING
Specialising in:
-Haltech
-Full Rewires
-Engine conversions
-Custom Air Con. Installations
-Drag, circuit & show car wiring
Justin Moore
0402 727 834
http://www.facebook.com/profile.php?...88667244568569
thanks so much for the help so far guys! also like you said turbo ke20, i need to run a tachometric relay to run the fuel pump, sideshow is helping me out with that one.Originally Posted by turbo ke20
ok just a few wires i can recognize i think might help you out.
plug CF1
green/white = stop light input (splice into stop light circuit)
black/yellow = alternator ignition sense wire. (joins to white/red to external reg plug)
black/orange = main ignition supply to ecu. (run through a fuse)
CF2
yellow/green = alternator warning light (goes to dash cluster)
black/white = start input from key (prob goes throught inhibitor switch on the gbox)
yellow = power via 10amp fuse (power suplly to speed sensor)
thats a starting point to get you going.
Specialising in:
-Haltech
-Full Rewires
-Engine conversions
Justin Moore
0402 727 834
No need. be a bucketload easier to wire though.Originally Posted by turbo ke20
i'll second that, leaves room for improvement if you can afford it up frontOriginally Posted by PsyCo JZX83
im not disagreing that they arnt easier.
id prefer to wire aftermarket any day, but in this case I think he wants to keep it standard so im helping him out.
Plus if he is prepared to spend a few grand on a haltech, autronic or motec id say go ahead otherwise i wouldnt bother wiring up any other brand.
If he wants a shit cold start and poor fuel economy then go fit ems or microtech.
Specialising in:
-Haltech
-Full Rewires
-Engine conversions
Justin Moore
0402 727 834
hey guys, i would fit aftermarket if i'd have the funds for big single turbo etc but at the moment i will be happy just running stock twins and ecu, as there is alot goin on with the rest of the car atm and financially as i am in the process of moving, in saying that justin and i are working on just getting it running for the moment as he knows abit or too haha, but thanks for all your feedback so far! the more the better
