Page 3 of 3 FirstFirst 123
Results 31 to 45 of 45
Thread: aftermarket throttle body - for 1UZ - what options are there?
    Penrith BC
    Default Re: aftermarket throttle body - for 1UZ - what options are there?
    in summary - lower manifold is a piece of shit if youre seeking improvement without boost
    if you want to waste time and money on these engines, replace this, THEN bolt stuff on top. let the thing breathe and get some rpm into it. then again, want to make an adapter and bolt onto oem, go ahead, but dont say your werent warned!
    20v throttles will look like sex, and go like a fart - just ask denzel! poor sucker. even damiens was a little underwhelming despite cams/throttles etc etc
    ../delete/ban
    tech moderator
    to ask a stupid question, what is the lower manifold... im used to nissans, where i have a plenum (intake) and an exhaust manifold... please explain the lower manifold to me..
    The manifold is 2 pieces. The plenum (chamber) and the runners.
    The runners are the lower manifold.
    cool... figured as much, just didnt want to gob off and get shot down
    so what makes the 2 x 20v throttles not much chop? too small a diameter?
    Mainly the quality of the manifold you bolt it to.
    Plus, they are a tad too small for high hp NA motors.
    I think the blacktops are bigger than the silver tops, but not sure by how much.
    I see, heres the specs anyway:
    silver: 43mm
    black: 45mm
  8. #38
    Jan 2007
    queensland
    make sure when you get the extractors fabricated they use tapered merge collectors, depending on other mods somewhere between 15-18deg would be best for street with a bit of a steep stepped taper out to the full size of the system..
    i run an 18deg merge from the pacemakers to a single 2.5" mandril system on my 3.5 v6 verada, i would have done mergies on the 3-1 section, but ere isn't enough room to put an effective merge collector..
    just doing this mod alone dropped my 1/4 time .4 sec....
    now she runs flat 16's!! (sigh................)
  9. #39
    what about collectors that used a radius on either side to merge together F1 style?
    like this:
  10. #40
    Jan 2007
    queensland
    yeh they look like they will work at 14000 rpm
    highly doubt they would be benificial with the gas speed and heat were talking about..
    i'm talking more like this..
  11. #41
    yeah ok I wish I understood the theories behind collector design. Are those from Burns stainless?
  12. #42
    Jan 2007
    queensland
    however i would like to see the inside of one of those collectors..
    this is one we did a few weeks ago on the 2-1 section on the pacemakers.. excuse the unpainted nature and the only pics i took was just after we had tacked it, TIG'd it on the bench.. there all painted up now and look shmick.. you can see how we couldn't run them on the 3-1 section and keep equal lengths without fabricating the entire rear bank again... which we didn't really want to do as they were a free set of pacemakers that i got with 2 squashed pipes (accident)
  13. #43
    Jan 2007
    queensland
    nar i just punched them in off google.. dunno where there from
    the 2-1 merge in the pics above is a mates workshop.. he fabricates them to formulae pending on engine specs/ intended use etc etc.. Extreme Custom Engineering in brisbane
    Mat
  14. #44
    looks really good Matt
    anyway we better get back on topic
  15. #45
    Gearwhore. Backyard Mechanic
    Oct 2008
    Quote Originally Posted by mattysshop
    Mat
    He's considering getting merge collectors pre-cut, we were talking about it the other day. As useful as it is, it's only really financially viable if you're buying 100 sets.
    Anyway, +1 for Craig. He really knows his shit
  1. TUTORIAL: How to build a 'cheap' 5S-GE motor from 5S-FE
    By bajachris88 in forum Tech and Conversions
    Last Post: 21-07-2010, 09:15 PM
  2. Throttle body boring in Brisbane?
    By TERRA Operative in forum Tech and Conversions
    Last Post: 08-02-2009, 10:32 AM
  3. aftermarket ecu options for 4agte?
    By phil in forum Tech and Conversions
    Last Post: 07-08-2008, 01:25 AM
  4. Quad throttle injector options
    By jezza323 in forum Tech and Conversions
    Last Post: 26-07-2007, 06:32 PM
