Page 5 of 7 FirstFirst ... 34567 LastLast
Results 61 to 75 of 92
Thread: 1GGTE TVIS + Aftermarket ECU and BB Turdbro
  1. #61
    Default Re: 1GGTE TVIS + Aftermarket ECU and BB Turdbro
    Quote Originally Posted by Kedderz
    Have a tutorial yes but 5 minutes with someone who has done it before will set me 100% on the correct path, thats how ive always learnt
    This TVIS thing is shitting me to tears so many varying views and none of them take into account the inlet manifold which has been ported/honed/balance tube fitted.
    Put it this way, I have less capacity, less cylinders, less torque and my TVIS is long gone and I have no need or want for it at all.
    A little more torque down low a little more restriction up top, just get rid of it and move on, guarantee you'll be fkn happy as a homo at mardi gras with or without it.
    My KE25 thread
  2. #62
    This may sound very noobish, but how do you remove the manifold fastening studs from the inlet side of the head? They will have to be replaced as the threaded section is too short.
    RA23 - Twincharged
    JZZ20 - Daily
  3. #63
    A few methods:
    Best method - lock two nuts together on the stud and then use a spanner on the inner nut to unscrew the stud.
    Worst method - Use pliers if they are not tight and you are replacing them.
    Costly method - If super stubborn use a stud remover.
    My KE25 thread
  4. #64
    Yo can use a stud remover socket or just screw two nuts onto the stud one on top of the other, then undo the nt closest to the head. This will pull that nut up hard against the other nut and turn the stud.
    Damn beat me to it. I will be the first one to use the term double nutting here though so that's something
  5. #65
    Quote Originally Posted by Joshstix
    It's appropriate that a search for "two nuts one stud" comes up with a thread by Kedderz.
    My KE25 thread
  6. #66
    Ive seen my dad do the two nut thing, ill give it a go, thanks guys.
    below me tom is sure to post something humorous no doubt involving chubbs....
    RA23 - Twincharged
    JZZ20 - Daily
  7. #67
    Google two nuts one stud and it comes up with a pick of you teabagging Tom.
    Another thing to think about, as you are spinning the tyres through the first few gears do you think you'll be thinking "gee I wish I had some more torque at 2000rpm"??? Probably not.
    My KE25 thread
  8. #68
    RE small torque loss, you're right. I probably wont notice it because who builds something like I am to drive around off boost.
    I do have to say I am a bit perplexed as to why the system was included in a boosted motor from factory. On a NA motor I can definitely see the benefits but a turbo charged engine goes from needing small air volume to a much larger volume relatively quickly thus sort of negating the need for the system as there is such a small rpm range in which it should actually close the secondary runners.
    Maybe it was used to reduce turbo lag?
    RA23 - Twincharged
    JZZ20 - Daily
  9. #69
    Convictania
    Chubbs teabagged your dad?
    fuck, I leave the thread for 5 minutes..
    sidenote:
    weren't the stock turbos on the 1ggte small, and are they set up sequentially?
    Didn't think they'd need to worry about turbo lag..?
  10. #70
    1ggte turbos are parallel ie exhaust gases are spinning both turbos at the same time.
    As tiny as they are, they still have a bit of lag.
    RA23 - Twincharged
    JZZ20 - Daily
  11. #71
    Convictania
    Ah well, you had the option of ggze
  12. #72
    pfft 1ggze. only thing they are good for is allowing a stonking great turbo to be used higher in the rpm range.
    RA23 - Twincharged
    JZZ20 - Daily
  13. #73
    Convictania
    Turbo cars need a bit of lag, its character.
    Obviously a circuit cars another story but for a registered street car I like a little bit of lag, thats the toibo experience!
    I'd rip it out and let your peak power do the talking.
  14. #74
    tom does make a good point with the stock turbos though, i mean going from a shit flowing exaust manni where both exhaust routes are competing to escape, to a good flowing single mannifold. this will on its own eliminate a lot of load from the motor
    lot to mention ditching power steer and A/C pumps, i stick with my decision to ditch the bastard
    let us know how the iscv goes though!
  15. #75
    Ok, im dumping the bitch.
    DONE!
    RA23 - Twincharged
    JZZ20 - Daily
  1. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 07:10 AM
  2. HELP: 1GGTE running slow, Error code 11.. what is it? *FIXED*
    By Jabtronic in forum Tech and Conversions
    Last Post: 31-01-2009, 01:05 PM
  3. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 06:31 AM
  4. Aftermarket ECU for 1GGTE
    By Adash=P in forum Tech and Conversions
    Last Post: 09-07-2006, 01:25 PM
  5. TVIS or not to TVIS...
    Last Post: 12-01-2006, 06:46 AM
