incorrect AFRs from the wideband doesn't cover why the zorst is running uber hot?
fwiw: my innovate wideband would regularly reset itself if you tried to crank/start the car with a failing battery (or neglected to fix dodgy earths).
Mine wasn't, it wasn't a kit either. They'd shipped it with some retarded firmware. Reflashed it with the current (current was like G and mine had H) and it worked perfectly.
Hmm, I thought you orginally bought a kit.Originally Posted by JustCallMeOrlando
Will have to get it looked in to.
Update on this.
Had a dyno day the other weekend. I asked the guys to compare my o2 sensor with theirs, but unfortunately they didn't.
Anyway, on the dyno print out she sat at roughly 12:1, which for a full throttle run is much leaner than factory.
http://www.conceptual.net.au/~peewee/v8supra/dyno.jpg
So today I had someone come over who also has a techedge wbo2 (same sensor, different controller) - (thanks Peter).
Put my sensor in his car, pretty much identical results to his.
Put my whole sensor/controller/display in his car, pretty much identical results to his.
So we've established that the o2 sensor IS reading correctly. And thus my car IS running lean (16.2:1 on the freeway).
So... why?
Possible thoughts are injectors need a service (tested with spare set same result, but I'll get them serviced anyway), or major vacuum leak somewhere.
Any other thoughts ?
I'm 99.9% sure I've got the right injectors for the ecu, but I'll get the ecu part number and check it out soon.
is the FPR ok?
Yep .Originally Posted by CrUZida
You must have another 1uz afm lying around? Worth trying?
Who said 16.2:1 (freeway) is lean ????Originally Posted by CrUZida
A whole lot of nonsense about nothing.
The only other one I have is the one on the Celsior.Originally Posted by whatthe?
Worth a try yep, but doesn't explain why it had the same problem with the Delco ecu.
Cheers for the valuable input...Originally Posted by rms
ok, to follow through on erols point (yes i too am a skeptic!)...
you say its lean?
so what does that *mean* in terms of tuning, ie igni adv and tourque output?
are you just chasing the afr figure cause it doesnt sound right, or is there *actually* a problem? i havent read anything yet other than a whako number on the AFR gauge, and a hearty 12:1 power mixture (call me crazy but that sounds perfect?)
has this been on a dyno yet? (no, not a dyno day power run) a single hour could net you more information than weeks of assing about.
just curious to see what the actual *problem* is
../delete/ban
tech moderator
If it was tuned for this I would be happy.
But its not, its a stock Toyota ecu running 100% stock everything.
Going by 5 years of watching other people it should be running ~14.5-14.9:1 at cruise, it should be running well under 12:1 at WOT (closer to 10:1 judging by my last 1UZ).
The car doesn't drive right. Very hard to explain exactly what its doing though.
And no, it hasn't been on the dyno yet, mainly because I can't find anywhere who wants me to pay them to put the car on the dyno for an hour. I've had excuses ranging from "we're solidly booked for the next 4 weeks" to "sorry but our screen is dead" (wtf?)
chased all intake leaks yet?
and, chased any exhaust leaks before the O2 sensor?
Genie exhausts in Myaree have a dyno... give them a call i'm sure you can book it in for an hour within a week... i dynoed a few cars there and it was almost instant..Originally Posted by CrUZida
Not mineOriginally Posted by CrUZida
Only goes under 12:1 in the last 500-1000rpm. 100% factory 1uzfe & ecu
If in doubt power out
20 year old fuel pump as well ? When was the last time the filter was changed ?Originally Posted by RONA
And Stu, yep I have checked for all leaks, couldn't find any, but will do another check soon. Its getting a new exhaust at the moment which will eliminate all potential exhaust leaks.
