Page 10 of 10 FirstFirst ... 8910
Results 136 to 140 of 140
Thread: Running Lean - stumped as to why
  1. #136
    Canada
    Default Re: Running Lean - stumped as to why
    Where are you mounting the WB O2 sensors?
    (I'm a little confused - apologies if I missed it in a previous post)
  2. #137
    It was about 40cm downstream from the factory position (which was right at the back of the motor)
  3. #138
    what's the maximum amount of fueling change that the close-loop settings will change?
    fwiw: my MSextra setup had an AFR table but I set it up for a maximum of 5% (and then later 10%) change of fuelling to prevent this kind of scenario (close-loop sending the motor too lean due to suspect O2 readings).
  4. #139
    Canada
    Thanks.
    I have had SC400 (Canada) with bad O2 sensors cause a lean condition.
    Stupid as it may sound, I didn't realize you were still running the injection based on the original O2 sensors.
    Glad to hear you got it going.
  5. #140
    Yeah, the WBO2 was only installed to check, not to override.
  1. 18RG running too hot
    By shewiththe18RG in forum Tech and Conversions
    Last Post: 29-10-2007, 07:59 PM
  2. Running a speedo without speed sensor
    By 81rolla in forum Tech and Conversions
    Last Post: 21-10-2007, 04:46 PM
  3. Fitted quads on 16v, now running on 2 cylinders??
    By DaveW in forum Tech and Conversions
    Last Post: 01-08-2007, 09:16 PM
  4. running in oil - reccomendations?
    By AndyTTR in forum Tech and Conversions
    Last Post: 01-11-2006, 12:15 PM
