Results 1 to 10 of 10
Thread: Putting POD on 7MGTE MZ21
    Dec 2008
    Default Putting POD on 7MGTE MZ21
    Hi..
    I'm wondering if anyone can show me pictures of there pod on a 7MGTE..? Im hoping to put one in today so if anyone can gimme some tips let me no. thanks.
    do you get any performance gain out of a pod?
    Slanted Photographer Automotive Encyclopaedia LeaThaL's Avatar
    Aug 2006
    Default Re: Putting POD on 7MGTE MZ21
    hey mate
    7m runs a AFM so the only real way to put a pod filter on the engine proberly is to get an adaptor from somwehre like repco and bolt it over the end and checking it doesnt have a hole anywhere and then just puttin the pod over the end, its pretty easy but just watch it doesnt have any issues with RWC with the local whatever
    id have a pic but i cant seem to find it but check the members rides area and check for anything in there
    1 G L O V E
    88 Ga70 supra --- Under powered and over cooled Daily
    performance.....probably not. induction noise, yes.
    RA23 - Twincharged
    JZZ20 - Daily
    Western Aus
    the Z20/A70 airbox is a wicked bit of kit.
    if you want a real performance boost, cut the air feed out bigger, and fit a K&N filter.
    they're awesome cause they're properly sealed and shielded from hot air
    Dec 2008
    succesfully done i put a K&N filter on it sounds better (flutter noise) but no performance gain.
    horray for compressor surge!
    RA23 - Twincharged
    JZZ20 - Daily
    Western Aus
    why would you get a performance gain?
    youd get a performance LOSS from a pod from all the hot air.
    stock filters are fucking awse, and you'd have to work hard to pick up noticable power from just an air filter change.
    Aug 2006
    Quote Originally Posted by Kedderz
    lolz
    but in agreeance with eldar, do yourself a favor and get some sheet metal and bend up a decent CAI box for your pod to shield it from heat and introduce it with some ducting into the box
    1 G L O V E
    Nov 2007
    In some cases pod filters do give a small small gain, that of course depends if the stock air box is restrictive. In the 7m's case, the stock filters are fine. What EldarO mentioned is the best choice. Not only will you get better performance than an exposed pod filter, your less likely to get a defect, probably wont if it's boxed, but I don't know the rules too well.
    So why do I see all the high power cars (500rwkw +) with exposed pod filters?
    Any reasoning behind this?
    T'ville, QLD
    unless the filter is MAJORLY clogged, i went from 16km/L to 27 km/L when i changed the airfilter on my bike + butt dyno said there was improvement
    2T out 4A in....
  1. 7mgte power results (6 / 5mgte's welcome)
    By mux in forum Tech and Conversions
    Last Post: 16-08-2007, 05:41 PM
  2. Putting a 7MGTE into a MX83
    By PureHell in forum Tech and Conversions
    Last Post: 31-10-2006, 08:04 PM
