Page 3 of 3 FirstFirst 123
Results 31 to 35 of 35
Thread: Losing Coolant
    Default Re: Losing Coolant
    That means I might need a new thermostat gasket, as it will be surely get damaged when removed
    Should've thought about it more before I started flushing it now...
    Im in the process of flushing the system as I type
    Quote Originally Posted by Razor
    And that'd be all of a couple of bucks from Supercheap or the like (is it an o-ring or gasket style?), and maybe $15 for a new thermostat too (can't hurt to change it whilst you're there)
    not sure yet as I've never replaced the thermostat, I'll see when I take it off
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    Just take out the drain plugs...the thermostat is a bitch to get to and to go through all the haslle of refitting it and replacing the gasket. The drain plugs are located on the front and back of the block, below the exhaust manifolds. There a 12mm bolt. Just undo it...flush the system until these run clear and do whatever you want to clean the system out. Put the plugs back in, undo bolt on the top radiator hose housing, fill the radiator and allow to circulate through the system until water comes out of the top rad bolt. Finished, no gaskets required.
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    where abouts is the front drain plug? its impossible to see the rear one without lifting the car
  1. Sv21 coolant loss.
    By maurice c in forum Tech and Conversions
    Last Post: 11-11-2008, 11:29 PM
  2. 12R motor boiling out coolant
    By Centretek in forum Tech and Conversions
    Last Post: 20-02-2008, 12:09 AM
  3. 2JZGTE Engine Coolant Capacity? Aristo...or Supra
    By sbyder in forum Tech and Conversions
    Last Post: 08-03-2007, 07:08 PM
  4. Engine coolant overflow
    By Pearce in forum Tech and Conversions
    Last Post: 08-11-2005, 11:46 AM
