Results 1 to 4 of 4
Thread: 12R motor boiling out coolant
    Jul 2007
    Default 12R motor boiling out coolant
    I have a 1976 HiAce Commuter with a 12R motor.
    Recently, it dropped a valve head into #4cylinder. Destroyed the piston and the head but bore had only slight scratch.
    Fitted second hand head and piston. Compression test shows all cylinders within 5 psi of nominal, BUT, runs quite warm and blows out coolant as steam a minute or so after engine turned off.
    No appreciable bubbles in coolant, fuel /air mix OK,no surging of coolant when revved and no water in oil or vice versa.
    Any ideas?
    SC14 7AGZE Grease Monkey
    Jun 2007
    FL
    Default Re: 12R motor boiling out coolant
    Blows coolant out of what? radiator cap? overflow bottle?
    Did you try doing a coolant system pressure test?
    Tallahassee, FL USofA
    Even though the water temp doesn't seem to be much higher, that temp is just the average of what's coming out of the head. There is something in there that is at a MUCH higher temp then usual, and it boils over when the coolant flow stops.
    A clogged passageway in the head is very rare, so I think the radiator is clogged & your gauge isn't showing how hot it really is.
    Virginia
    leaking head gasket. Small leak from the combustion chamber to a coolant passage, Does it bubble like this? If so then head gasket.
    http://www.youtube.com/watch?v=NMCfTAjMJBA
    73 Celica (New track car) - 20/22R Hybrid, caged, built suspension, AE86 brakes, 5 speed, 155 rwhp, 165 rwtq all motor!
    86 Crown Vic (Old track car) - 5.0L HO, 2.5: dual exhuast, 5 speed, TruTrac 3.55, race suspension, race seats, grandma track car turned tow vehicle.
  1. Garrett Turbo coolant lines
    By NAJJE in forum Tech and Conversions
    Last Post: 27-03-2007, 09:15 PM
  2. 2JZGTE Engine Coolant Capacity? Aristo...or Supra
    By sbyder in forum Tech and Conversions
    Last Post: 08-03-2007, 08:08 PM
  3. does coolant go through here??
    By slide86 in forum Tech and Conversions
    Last Post: 01-04-2006, 10:33 AM
  4. Engine coolant overflow
    By Pearce in forum Tech and Conversions
    Last Post: 08-11-2005, 12:46 PM
