Results 1 to 7 of 7
Thread: 4age 20v head on 3sge mr2 block
    Low rep Grease Monkey
    Default 4age 20v head on 3sge mr2 block
    hi guys just thinking if the 20v head will bolt on the mr2 block.
    All so would it bolt straight in the ae82 or would it need fabrication and modification to the crossmember and stuff
    Default Re: 4age 20v head on 3sge mr2 block
    no and no............
    Gearwhore. Backyard Mechanic
    Oct 2008
    o_0 Is this a serious question?
    Forum Sponsor Conversion King
    Buy a Veyron, it will be cheaper and atleast work straight away.
    You must spread some Reputation around before giving it to The Real Roadrunner again.
    Jun 2006
    School Holidays started again..... didnt they?
    No... It won't work... besides... not moking the 20v but the 3sge engine heads are pretty good design anyway. None the less.. the 20v engines are just as well designed, and I do believe both heads were designed by Yamaha.
    If you do wanna have a 3sge... get the BEAMs NA engine... alternatively, keep it 20v al lthe way. You can increase displacement by either getting a stroker kit or using the 7A block.
    Up to you...
    MIKE
    _____________________
    Current ride: AW111 - http://aw111.blogspot.com
  1. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 05:53 PM
  2. 3SGE TPS Loom Plug Onto 4AGE Loom???
    By newbien in forum Tech and Conversions
    Last Post: 12-05-2008, 09:50 PM
  3. pressure tested and problems
    By 2revup in forum Tech and Conversions
    Last Post: 18-02-2008, 03:11 AM
  4. 3sge gen4 block + gen3 head ???
    By aw11man in forum Tech and Conversions
    Last Post: 13-10-2006, 06:01 PM
