Results 31 to 45 of 48
Thread: AW11 + Blacktop 20v Conversion - No Start...
    Default Re: AW11 + Blacktop 20v Conversion - No Start...
    Did you try without the LED in series?
    The LED and resistor in series will reduce the current flow to a level that won't make the injector operate / tick
    Try without the LED if you haven't already!
    Edit: There shouldn't any significant pressure in the return line... it is meant to be low pressure return flow to the fuel tank
    Wilbo's JZA80
    Wilbo's JZZ12
    Aug 2006
    success 6164
    it would be interesting to see if it is a stuck injector..when we cleaned them they were flowing fine on the test machine..the spray pattern was pretty much the same across all four and they all flowed roughly the same amount no matter what pressure and RPM we put through them.
    http://www.ae82ownersclub.com/forum.php
    powered by 4agze ae82 goodness.
    Ok... we just did another test...
    You are absolutely right about the LED... It won't fire the injector... here is what we did...
    We pulled one of the 16v injectors, and we connected it up (Yes same plug) and we could definitly feel the clicking.
    We then proceeded to wire up the 16v injector with the LED, and sure enough it didn't fire. He then basically removed the LED, and tested the injector, and that definitly caused the 16v injector to click...
    we then proceeded to perform the same test on the 20v injector, and again, no clicking sound... totally dead.
    We also checked the exhaust... there is definitly air movement through the engine, and hence, compression build up.
    Damo101... Thanks for your contribution... U must be the guy performing the 16sc engine @ Warren's place, right...
    MIKE.
    _____________________
    Current ride: AW111 - http://aw111.blogspot.com
    In the past I've used a higher voltage (Via a power supply, but two 12V batteries in series to give 24V should also work) to supply a larger current to the injectors to get them to 'unstick'.
    I simply applied 24V in short pulses (not constant -> to avoid heating up the injector solenoid winding and leading to failure). Until the injector ticked in the normal fashion
    You might try this (At your own risk ... I take no responsibility for injector failure, I wouldn't expect it, but anyway ),
    Wilbo's JZA80
    Wilbo's JZZ12
    SHE's ALIVE... SHE's ALIVE...
    Basically, we realised the injectors were stuck... so we basically applied 12v (cycling continuously) on one injector and all of a sudden it started clicking... OK....
    Did it to the second one... same... we fired it up... yes... but only running on 2cylinders.... OK...
    We did it to the next 2 and voila... she's come to life, and fired right up. Could let it run for too long, as no exhaust....
    Well... she's off to the exhaust shop soon, after I start cleaning up all the mess...
    Yeeeeeees... SHE'S ALIVE...
    Thanks for all you help... an no, I wasn't daring enough to apply the 24v...
    MIKE.
    Sep 2008
    i want pics and vids now...
    jump over to the aw11 owners annon and post up some stuff
    The GOD HAND AW11 - sold
    Hahahahaha... Thought that might be required....
    Don't worry... it'll all go up on my blog post...
    MIKE.
  8. #38
    Aug 2006
    success 6164
    nice one!!
    you will have to bring around the workshop one day mate.
  9. #39
    Hey Damo101...
    For sure will be... Can then compare notes...
    Besides... Will need to get you guys to give it a health check once it's all done...
    MIKE.
  10. #40
    Junior Member Carport Converter Mooro's Avatar
    Tasmania
    Excellent news...anymore updates...can't you bolt the old 16V exhaust up for a quick squirt up the road ?
  11. #41
    Hahahahaha... Yeah, I was hoping to do so, but defintly no can do... too much trouble fitting the old exhaust, as I would have to change the Headers too. Besides, got the Mr2 booked in for the exhaust on Tuesday mornign with Norm Butler exhaust.
    But will definitly be putting up an update then... ;-)
    MIKE.
  12. #42
    Sep 2008
    needs more UPDATES
  13. #43
    UPDATES available...
    MIKE.
  14. #44
    Tasmania
    <heads to http://aw111.blogspot.com/>
    Still no first drive impressions etc...
  15. #45
    hahahahahahahahaha.... Picky, Picky, Picky, Inpatient, Inpatient, Inpatient...
    I called up the exhaust shop on Friday, and yes, the car was ready to be picked up, but alas, I had no time on friday, so it will be a monday morning job. Will be giving further updates then as I will be driving the car to work & Back, after pickup. A bit risky, but... Oh well.... I will be giving updates then.
    With regards to driving experience, I did have the oportunity to drive up steep driveways, and the likes... A LOT MORE TORQUE than the old 16v... I remember the old engine used to strugle to get up the drive way of the workshop, where I had to put it in first and rev to about 3000RPMs and ride the clutch (Otherwise wheels spin)... now, 1500rpms and no requirement to ride the clutch.
    But when I called the shop, they indicated that it has a nice deep note, as it's 2.5" all the way, with a custom mufler and a 2.5 High flow metal cat... Anyway... Pics will be following...
    None the less... I find the clutch a bit spongy... but that could be because I've been spoilt with an Auto Forester for the last 6 months...
    Anyway... Updates to come...
    MIKE.
  1. MA70 --> JZA70 Conversion
  2. Clarification of Technical FAQ and Conversion Threads
    By river in forum Toymods Car Club Membership and Feedback
    Last Post: 05-06-2006, 09:20 AM
  3. 3S AW11 conversion: few detail
    By mullett in forum Tech and Conversions
    Last Post: 17-03-2006, 11:17 AM
