Here is a section taken from my Wolf V500 ECU's date logging.
The top graph is Green RPM and Orange Throttle position..
The middle graph is MAP in Dark Blue and Boost in Light Blue
The bottom Graph is Red pre intercooler Temp and Dk Green post intercooler Temp.
Note the last graph the scales are different by 1.82:1 so the red should be almost twice what is shown. If the graphs were true to each other then the red at the start would be almost twice the height of the green. As pre intercooler temps sit around 45 Deg C with the heat soak from the engine after a 30min warming up. Post intercooler temps sit around 26 Deg C, ambient 19 Deg C. The red line would also increase in height by almost double if the scales were the same.
Hope that all makes sense.
The important thing is this is a run from second gear (as we don't use first except for step hills and off road, in fact Off road Low Range First is only used down hill.) to 3rd to 4th to 5th at full noise foot hard on the floor. Rather than a single gear run on the dyno.
Note it was also up hill.
The Dk Green line never moveswell maybe just a tiny bit.
) : Wakefield 1:16.1 Racechrono
