Results 16 to 20 of 20
Thread: vvt not working 20v
    T'ville, QLD
    Default Re: vvt not working 20v
    Quote Originally Posted by Mr Revhead
    its on from pretty much idel if you use full throttle
    and switches off around 6
    you are thinking of vvti my sheep shagging brethren the silvertop vvt is on at x rpm and off at y rpm, throttle makes no difference
    2T out 4A in....
    New Zealand
    no im not
    VVTi alters the timing a variable amount
    VVT a set amount, its basicly a switch, on or off.
    in the 4ages its determined by load/throttle/engine temp etc
    ten mins with a VVT light hooked up will show you that once the temp gauge has reached 1/4 heat anything over half throttle is enough to switch it reguardless of the RPM.
    infact its pretty much impossible to drive the car with out activating it.
    some ppl have said the preface lift ae101s had an RPM based VVT, but mine was preface lift and it wasnt like that. maybe the very first version of it was, but i dont have a list of ECU p/n changes anymore so im not sure when that was likely to be.
    please, no more PMs!
    Quote Originally Posted by shelldrake
    Speaking to someone who works at toyota recently - They said for all cars up to and including vvt function they use a 20w-50 multipurpose. vvti is different...
    Do you mean "all cars up to and including VVT-i function they use a 20w-50 multipurpose. VVTL-i is different..."?
    I thought the VVT and VVT-i engines use the same oil?
    ([][][]II--LT--II[][][])
    Sep 2008
    are the VVT different between the blacktop and silvertop, i think i read somewhere the blacktop is throttle based and the silvertop is RPM based?
    The GOD HAND AW11 - sold
    New Zealand
    Quote Originally Posted by X kyle X
    yes, the pulley moves by different amounts. as for switching parameters, iv only ever tested silvertops. all the ones i tested most definitely were not RPM switched
  1. TA22 indicators not working
    By joey in forum Tech and Conversions
    Last Post: 30-07-2008, 08:49 PM
  2. Low beam headlight not working (ae86)
    By Julz01 in forum Tech and Conversions
    Last Post: 24-07-2008, 03:11 PM
  3. Reverse lights not working (GZ20/1JZ/R154)
    By Hengsta in forum Tech and Conversions
    Last Post: 30-05-2008, 10:54 PM
  4. How to fix your ST162 tail lights when they stop working
    By mikie_121 in forum Tech and Conversions
    Last Post: 08-04-2008, 03:24 PM
  5. Speedo not working in my Z10 Soarer
    By orestes in forum Tech and Conversions
    Last Post: 07-03-2006, 02:36 PM
