Results 1 to 4 of 4
Thread: Reverse lights not working (GZ20/1JZ/R154)
    Junior Member Automotive Encyclopaedia Hengsta's Avatar
    Default Reverse lights not working (GZ20/1JZ/R154)
    Howdy guys, im in desperate need of help as i got a inspection on the 13th June and want my reverse lights to work before i go.
    The plug thats coming out of the box is connected but still reverse light is not working
    Anyone have a clue why its not working?
    If so please explain in detail.
    any help will be much appreciated.
    Thanks,
    Heng
    -Sleeper 2J + R154 X83
    -GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
    Default Re: Reverse lights not working (GZ20/1JZ/R154)
    A few things I'd check
    If the reverse switch in the gearbox is working:
    >Unplug the gearbox reverse switch plug
    >Use a multimeter to check that the pins on the plug are connected when in Reverse, and not connected when in any other position.
    Check to see if you have power to the gearbox reverse switch:
    >You should have power to one side of the gearbox reverse switch, if the car was previously auto it will be the wire that was used as the common power to the gear position indicator switch.
    Check to see if the other side of the reverse switch is connected to the reverse lights.
    Check to see that the reverse light bulbs aren't blown.
    Check to see that the side of the reverse light bulbs that doesn't go to the gearbox reverse switch goes to ground
    Hope this helps...
    Lol abit confusing but will check with a mutimeter.
    Yeah the car was originally auto. hrmm i have been reading it through like 3 times now but still dont really get what you trying to say for this bit lol (if the car was previously auto it will be the wire that was used as the common power to the gear position indicator switch.)
    Cheers for the help anyways mate +rep
    Quote Originally Posted by Hengsta
    OK.
    You know the rather large plug that used to go to the position indicator bit on the side of the auto gearbox? The bit that the shifter linkage connected to?
    On the plug that goes to the auto gearbox position indicator will be a wire that has the power that should be switched to the reverse lights...
    When the car was auto, the position indicator switch was used to 'switch' the common power to the other pins... i.e. power goes to the auto position switch on a pin, and when the shifter is in D if comes out on another pin, and when in R another pin, and so forth for all the other gears
    Does that make sense?
    Which other bits do you find confusing?
  1. Puttin 71-72 tail lights into a 73 onwards celica
    By suss_slide in forum Engine & Driveline Conversions
    Last Post: 30-01-2008, 05:34 PM
  2. interior lights playing up
    By DQIKST in forum Tech and Conversions
    Last Post: 28-09-2006, 06:43 PM
  3. Wiring up SpotLights and Fog Lights to AE102 Corolla
    By birdie in forum Tech and Conversions
    Last Post: 28-06-2006, 07:22 AM
  4. A340E lost reverse :(
    By whatthe? in forum Tech and Conversions
    Last Post: 10-03-2006, 02:50 PM
  5. Speedo not working in my Z10 Soarer
    By orestes in forum Tech and Conversions
    Last Post: 07-03-2006, 02:36 PM
