Results 1 to 15 of 24
Thread: 1jz ISCV stuck open. cleaned but no better. last post edited
    JZZ20 Backyard Mechanic forey's Avatar
    TAS
    Default 1jz ISCV stuck open. cleaned but no better. last post edited
    turns out its the ISCV stuck open
    87' z20 Soarer - 1jz Gt35r -
    TAS
    Default Re: 1jz in z20 problems
    as above..
    TAS
    Default Re: 1jz problem not fixed, but problem found
    bump sorry, pretty desperate
    Nov 2007
    There was a thread by Lambolica about cleaning ISCV's. If I remember correct you have to clean the oily sludge buildup that keeps the ISCV sticking open, but there are some precautions to take when doing this.
    Try do a search and you may find his thread.
    Step 1, check to see if it has power.
    Wilbo's JZA80
    Wilbo's JZZ12
    Mechanic Grease Monkey jzx81mx83's Avatar
    W.A
    man my 1j wouldnt idle and i had power 2 iacv it turned out to be a vac leak always look for the simple things first
    cheers Nick
    __________________________________________________
    89 GX81 Grande with manual single turbo 1jz
    TAS
    yeah if i put my hand over the "outlet" of the ISCV but not block it off fully it idles almost perfect. the problem is with my custom plenum its virtually impossible to get the bolts off to clean it! im not sure a way around it other than loosening a engine mount and jacking it up on one side...
    old engine bay pic but you get the idea, from the top you can barely get your hand in there let alone a tool. and from underneath you can possibly get one of them with a big extension but not the other
    Forum Sponsor Conversion King
    Dec 2006
    as per what Wilbo has said, check if the ISCV has 12v power to it, if it doesn't it will be in the fully open position (factory ECU does this for quick startup) so cleaning it won't do sweet FA.
    IF it has got power then and only then would i try to remove it and clean it.
    IF your to lazy to do that the grab a big set of sidecutters and clamp the pipe down until you have reached the desired idle when hot (needed a quick fix on my hilux/surf/wreck thingy)
    linden
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    I have the same ISCV problem, stuck at a certain position. Plugged in another ISCV from a 1G, that worked perfectly. It seems the valve is stuck on the 1JZ ISCV, I can hear the stepper motor trying to move the valve when I apply power to the middle pins and ground the outer pins, but the valve never moves. Soaked it in WD40 for a few hours too, still wont budge.
    Short of hitting the thing with a hammer, is there any way to pull it apart?
    your mums an Carport Converter pato's Avatar
    block off iscv, wind idler screw out to about .8% throttle,
    easy fix
    Quote Originally Posted by RAd28
    I certainly don't need to stick my hand in a blender to know it'll cut my fingers off, and i don't need to weave in and out of traffic at 120 to know it's fucking stupid.
    Quote Originally Posted by pato
    easy fix
    Elegance level = 0.0%
    Wilbo's JZA80
    Wilbo's JZZ12
    Yeh - I'd rather fix the problem personally
    Dec 2006
    If his was bad check out what i did sidecutters FTMFW!!!!!111eleventybillion.
    TAS
    again, the problem is getting the ISCV off the bottom of the plenum TO clean it., as far as i can tell there was no outlet pipe on it. could a engine breather be used in place of it?
    im pretty sure its got power since its only done it recently
    Dec 2006
    if it was working previously then you only have 1 option to fix it, remove it and either clean it or replace it with a known good one.
    id still double check that it has power first though it there is no point replacing it if the power ain't there.
  1. 2JZ Water Pump onto 1JZ
    Last Post: 28-10-2008, 11:33 PM
  2. MA61 + 1JZ + Heater problems
    By Gibbon in forum Tech and Conversions
    Last Post: 11-05-2007, 03:25 AM
  3. 1jz to 2jz
    By HIZOKU in forum Tech and Conversions
    Last Post: 30-11-2006, 07:52 AM
  4. 1jz and Haltech e6k
    Last Post: 10-10-2006, 05:25 AM
  5. 1jz problems with idle and snapped off screw head.
    By tyottsoarer in forum Tech and Conversions
    Last Post: 22-05-2006, 12:39 PM
